This instructable will show you how to make a "spooky fading eyes" circuit that can be used for Halloween decorations. All of the components should be available in any electronics hobbyist's box-o-parts, but if for some reason you are missing something, all parts are available from Radioshack.
Below is the summary of parts you will need. When I first started this project I came across several examples on the web that used OPAMP's, microcontrollers, or 555 timers. I am fond of designing circuits that do not require the use of any IC's, so here is what it takes to do that:
1 - 9V battery
1 - 9V battery clip
1 - 9V battery connector
1 - SPST toggle switch (single-pole single-throw)
1 - 100 ohm resistor
3 - 10kohm resistor
1 - 33kohm resistor
2 - 330kohm resistor
1 - 1Mohm resistor
2 - 10uF electrolytic capacitor
1 - 220uF electrolytic capacitor
3 - 2N3904 NPN transistor (or equivalent)
2 - LED (1.7V forward voltage, 20mA)
1 - Small perforated circuit board
1 - Breadboard (if you want to experiment or don't like to solder)
X - Screws (depending on what you mount the circuit to)
X - Wire
Remove these ads by
Signing UpStep 1The Circuit
The output of the astable multivibrator is slewed into a triangular shaped wave to control the final output transistor. This gives the fading in/out effect since the current through the base of the final transistor will transition slowly (i.e. not a square wave). Again, you may need to experiment with the value of the 220uF capacitor to get the best fading effect.
7
comments
Add Comment
gschoppe
says:
Add Comment
