This is a simple way to make a quite spooky looking hanging ghost. It can be draped over a tree or bush, or even hung in a doorway. It is back lit with clear Christmas lights, black lights. We have also used a floodlight pointed up to illuminate one we put on a bush. The basic construction starts with a positive mold on which your material is draped over the mold and coated with either polyester resin, plaster of paris or even papermache. The later 2 do not work as well as they are much more fragile and susceptible to moisture. I recommend going with polyester resin, and this is what will be covered in this instructable. The photos do not really do these ghosts justice as the lighting was effecting the digital camera. For some reason in the pictures the ghost faces are not as lit up as in real life.
Disclosure time: Polyester resin is nasty noxious stuff, it is bad for you and some people are allergic to it, as is the silicone caulking. Do all stinky steps in a well ventilated place, preferably outside. Don't be stupid, I am not responsible.
Remove these ads by
Signing UpStep 1Materials
- White sheet, table cloth or suitable piece of white material
- Mannequin head or Smooth plastic mask (life like)
- Polyester resin, plaster or paper mache
- Duct tape and/or clear packing tape
- Corn starch
- Clear Silicone caulking 100% pure (NOT type 2, 3 or paintable)
- Disposable mixing bowl capable of holding 2 liters
- Mixing sticks
- Disposable brushes
- Rubber gloves
- Piece of plywood or board at least 3 inches wider on all sides then your mask
- Optional tripod and matching nut to screw onto the tripod
- Aluminum foil
- Fast setting epoxy glue
7
comments
Add Comment
iminthebathroom (author)
says:
l8nite
says:
says:
says:
Add Comment
