Step 2Make a Clear Cover and Drill It
Use a circle cutting attachment on a drill press to cut out a 3.25 inch disc cover lid out of 1/8 inch Lexan polycarbonate.
Next, 1/4 inch holes are drilled in the cover lid for the two banana jacks and for the two audio jacks.
The two banana jacks will receive banana plugs with pre-mounted antennas.
Two audio jacks will also be used. One is for for audio out to the computer, and one is for an optional auxiliary input modulation from a hand gripper or other source.
Drill holes as seen in the photos, or lay out your own hole design. I drilled a total of nine holes;
Two 1/4 inch holes for antenna banana jacks,
Two 1/4 inch holes for audio jacks,
One hole for the variable capacitor shaft, and two small 1/16th inch holes for its screws
and two 1/16th inch holes to feed the diode wires to mount the diode on top of the jar lid (This is for better light-to-sound effects; as the 1N34A diode is light-sensitive)
Add Comment
