Spool Holder
Published
Introduction: Spool Holder
This device is designed to hang off the side of any level surface or table. It is used to carefully hold and organize spools of wire, solder, or even yarn.
Step 1: Step 1: Xyz
take 1/2" xyz joint, and place 2 in of 1/2"pvc pipe into the x axis side. take 2" of 1/2" pvc pipe and fit into the y axis. do this for both left and right sides.
Step 2: Step 2: Elbows
insert 2" of 1/2" pvc pipe sticking out of xyz joint into 90degree pvc elbow. insert 2" pvc pipe into other side of elbow. do this for both sides.
Step 3: Step 3: Spools
insert one end of 12" wooden spool into the 2" of 1/2" pvc pipe coming out of xyz joint. insert one end of wooden spool into 2"' of 1/2" pvc pipe coming from the open end of the elbow piece. repeat for both left and right ends. Add Spools
Step 4: Step 4: Mounting Elbows
insert 2" of 1/2" pvc pipe into both xyz joints. attatch 45 degree elbow pieces to both 2" of 1/2" pvc pipe.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
