Introduction: Spray Can Nozzle-tube Holder(detachable)
Picture of Spray Can Nozzle-tube Holder(detachable)
Feed up with spray can nozzle tubes going walkabout?
Here's a way of holding them in place
Thanks to spu3 and his   Make a Spray Can Nozzle Holster using Sugru    'ible   for stimulating this idea.
Decided some 2½inch(65mm) corrugated drainage hose on site could clip on to the can and hold the tube.
I cut off 4 corrugations from the hose and after drilling the holes through the corrugations to hold the tube I realised 2 corrugations were quite enough to hold it, so cut it again to give me 2 holders. A cut was also made across the circumference to allow the hose to spread and be clipped around the can.
I angled the holes thinking it might make it easier to extract and insert the tube, but you may prefer to keep the tube parallel with the can.
 This clipped easily to a 2½+inch diameter can.
For a 2+inch diameter can I used a piece of the hose left from making a clip/holder for some PVC pipe, cut off 2 corrugations, drilled them and used a plastic wire-tie to hold it to the can.
spu3 's 'ible led to this. Maybe this will led to another idea.
Unpunched drainage hose was used. Maybe hose with holes prepunched would also be suitable. I recall an old vacuum cleaner hose that may have been suitable for the smaller diameter can.  I'd be happy to accept suggestions for other/more common? materials, or see your instructables using them
mole1 (author)2012-10-20
That looks really sturdy! Losing the tubes to full cans of stuff has to be one of the most maddening things that happens to almost everyone sometime. I'm surprised that hardware stores don't carry assorted bundles of common sizes of tubes. I now use the ribbing from socks and put a tape 'flag' on the tube so it can't slip through. (It's in 'Things to do with pantyhose and socks besides wear them' ible.)
davatr (author)mole12012-10-22
Thanks for that idea. I like it. -and many great ideas there.(note to self: I must not now start hoarding old socks)
About This Instructable
2,871views
6favorites
License:
More by davatr:Cheap (ugly?) Camera mount for motorcycleSpray can nozzle-tube holder(more detachables)Spray can nozzle-tube holder(detachable)
Add instructable to:
