Spring Scarf From Old T-shirts
Introduction: Spring Scarf From Old T-shirts
Here in the Dirty South, we've been having some unseasonably warm weather, but the nights are still pretty cool. It's that in-between time when you want a scarf, but not a heavy one. So, after being just slightly too cold on my dog walk this morning, I decided to make myself a medium weight scarf out of some old graphic tees I had laying around. The result turned out to be the perfect weight and I dig the way it looks. This tutorial originally appeared on my crafting blog: DudeCraft.com
Step 1: Step One
Select two old t-shirts.
Step 2: Step Two
Cut the T-shirts into strips. I made mine 8" wide, but you can use any width you want. Also, I cut my strips horizontally to highlight the t-shirt's designs, but cutting vertically will work just as well.
Step 3: Step Three
Step Three - Select two strips to begin with and pin them right side together on one of the short sides.
Step 4: Step Four
Sew along the side you pinned.
Step 5: Step Five
Keep repeating this process until you have two pieces that are the length that you want the scarf to be when it is finished.
Step 6: Step Six
With right sides facing each other, pin the long sides of the two pieces together and sew, making sure to leave the ends open.
Step 7: Step Seven
Turn the scarf right side out and stitch the ends closed about two inches from the bottom. In this photo, my pieces are two different lengths. I cut the green piece to even them up after I sewed the end shut. No worries!
Step 8: Step Eight
Make fringe at the end simply by cutting slits with your scissors.
Step 9: Step Nine
Wear and enjoy. Original tutorial appears on my blog DudeCraft.com
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    I used this to make a scarf today. Great idea! Too bad I have to wait a while before the weather cools down enough to wear it!
    very nice. btw, where is the "dirty south".
    definitely an awesome dude project hahah, thanx
    very sweet fan... i liked it
