3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sprinkler valve air cannon
This instructable will show you how to build a Pneumatic cannon utilizing a modified sprinkler valve. Yes, I know that this has been done before, and there are a few other good instructables on this subject, but what sets this one apart is the valve modification. I have noticed on other instructables they merely tell you to "go to spudfiles and figure it out yourself." This took quite a bit of research on my part to figure out exactly how to do this correctly. Therefore, the main focus of this instructable will be the modification of the sprinkler valve. also, there will be no image notes until the bug gets fixed, sorry.
Step 1Disclaimer
This is so important, it requires it's own step. DO NOT!!!!! UNDER ANY CIRCUMSTANCES!!!!!! USE CELLCORE PIPE!!!!! IT WILL EXPLODE AND YOU WILL DIE!!!!! also, never pressurize this cannon above 100psi. That is the ABSOLUTE maximum to EVER take an air cannon. Also, this is very dangerous. undertake this project at your own risk, and fully understand that this cannon has the potential to explode at any point and time. Oh yea, one more thing.... DON'T USE CELLCORE PIPE!!!!
7 comments
Apr 18, 2011. 8:26 AMscoie says:
boom
Mar 18, 2012. 2:08 PMElectroinnovation says:
yes listen to him..I've had an air cannon blow up right next to me twice. Not fun....
Mar 10, 2012. 11:36 AMhyperr says:
I have the exact same valve as u do. I tried your mod and It doesn't seem to work well.. Does it matter which way u place the valve?
Oct 28, 2011. 5:49 AMstevenh429 says:
whats the sliver of 1/2" diameter pvc for?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
47
Author:iloveairsoftstuff
A mechanical engineering major at JBU, I enjoy putting motors on things that don't already have them, tinkering with small gas engines, airsoft, paintball, and pyrotechnics
