3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sprocket & innertube belt
Step 2Break down your bike parts.
For the base of the belt, take one innertube and cut it 2-3" past the valve stem. You should now have a long strip of tubing with the valve stem close to one end. Measure around your waist where the belt will sit, then add 8-10" to that measurement for the tail of the belt -- this measurement is the total desired length for the belt. On mine, the total belt length is 36", with an extra 2" of tubing past the valve stem to fold over for the belt buckle.
Lay your proto-belt out flat, then measure out the length you just calculated, starting at the valve stem. Mark and cut the tubing to that length. (Note: You're ignoring the 2-3" of tubing on the other side of the valve stem because that's going to be folded over later.)
From the tubing you have left-over, cut a 1"-wide section. This will be the...um...the little loop that you thread the tail of the belt through after it goes through the buckle. (Is there a word for that? If I poked the internet to dig up the proper word for that, would anyone know what I was talking about?)
For the sprocket, you may be able to find a lone sprocket wandering around, or you may have to detach it from a cassette and clean it up. You want one where the inner diameter is slightly smaller than the length of the valve stem.
For the bike chain bits, you can start with an old, worn, greasy chain and clean it up, or just buy a length of new chain -- less cleaning, more shiny! Since Fjord did all this work long before these pictures were taken, I don't have photos of the process. The idea is to take the chainbreaker tool, disassemble the chain, and separate out the flat top & bottom pieces of the chain. You'll then stitch the flat top & bottom pieces onto the belt with strips of rubber or elastic cord. Design your pattern first to figure out how many chain-bits you need; my belt has two rows with 22 chain-bits in each row, so 44 flat figure-8 chain-bits in total.
2 comments
Oct 15, 2007. 11:21 AMWurdBendur says:
That little loop is called a keeper, because it keeps the tail of the belt in place. I'm not sure how many people will know this word.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:reno_dakota
