Step 5Yet more hole-punching!
Flatten out the tubing again. Mark two parallel lines down the length of the belt, with whatever spacing you want between rows of bike-chain bits. On my belt, there are 22 pieces of chain-bits in each row. The holes in each figure-8-shaped chain-bit are 0.5" apart on center, and they're spaced so that there's 0.5" from the center of a hole in one chain-bit to the center of the hole in the next one over. The chain-bits alternate between the flat (shiny) side and the not-flat (grungier) side, and are laid out end-to-end.
You could use this same pattern, or lay the chain-bits vertically or diagonally instead of horizontally, use different spacing, or stitch on entirely different beads/hardware/etc for decoration. Get creative with it, make it your own thing. Remember, though, if you're stitching chain-bits on, you'll need to punch a hole directly underneath each of the two holes on the figure-8 chain-bit, so your pattern will be made up of pairs of holes set a fixed width (0.5", in this case) apart.
Add Comment
