The Instructable brought about many requests for additional mental math skills, if I happened to know any, and concerns about the practicality of mental cube root extraction. Of the comments, however, one in particular intrigued me. A lone user suggested I apply the concepts of Vedic Mathematics to my mental math repertoire. Having never heard of vedic mathematics, I went and found what I could off the internet. What I found was fascinating, and I will share with you a trick from Vedic Math today. So today, I will teach you how to square 2 digit numbers mentally, enjoy!
For more information on Vedic mathematics, including the background and history of Vedic Math, check this out.
Remove these ads by
Signing UpStep 1A Note on Practice
So, if you find you can't solve mental squares as quickly as you'd like, one of the best ways to improve is to write out a whole bunch of multiplication problems on a sheet of paper, things like 25x46, 17x64, 7x920, and so on. Then, mentally solve them (don't write anything down, no calculators!) and finally, check your answers with a calculator. The more mental math problems you do, the better you'll be at it.
It should be noted that 2-digit integers will be used for the most part in this Instructable. However, the techniques presented here can be applied to decimals and numbers of arbitrary length. With practice, it is possible to mentally calculate squares of decimals and 3 or more digit numbers. The only limit is your ability to remember numbers and multiply numbers mentally quickly.
whenever you have a number which ends in 5 you can use this. multiply the number preceding 5 with its successor. say you have 75 then multiply the preceding number 7 with it's successor 8 ( for 85 it would be 8*9), Write down the result and just write 25 to the end of this result.
So 75*75 = 7*8 = 56 now write 25 to the end of this digit = 56 25 this is the ans 5625.
The idea is to treat the number as 2 distinct numbers 1st part is the number preceding 5 and the second part is the digit 5.
so for 125 * 125 we get 12 & 5
12*13 = 156 and write 25 to the end = 156 25 ---> 15625
1. we get the digit sum of a no. by "adding across" the no. For instance, the digit sum 0f 13022 is 8.
2. we always reduce the digit sum to a single figure if it is not already a single fig.
3.In "adding across" a no. we may drop out 9's. Thus if we happen to notice two digits that add up to 9, such as 2 and 9, if we ignore both of them; so the digit sum of 99019 = 1 at a glance.(If we add up 9,s we get the same result)
4. because :nine don't count" in the process, as we saw in3 step, a digit sun of 9 is the same as a digit sum of zero. The digit sum of 441,e.g = 0.
You may use this for Multiplication, Cubes , Squares etc.
you may also check weather your squared no, is correct or not.
I will explain it:-
take an example for 207.
square(207)= 42849
now add digits of LHS and RHS separately. we get
Sq(2+7) = 18
Sq(0) = 18
0=2+7
0=9
0=0
thus your calculation is correct.
take another example.
Sq(897) = 804609
sq(6) = 18
36 = 180
0=0.
Thanks,
Purduecer
Ever wondered why, for instance, 9*11 is one less than 10*10? 4*6 is one less than 5*5? 164*166 is one less than 165*165? (It is, trust me).
This is a specific instance of the identity (x+a)(x-a) == x2 - a2, called completing the square, and the Vedic squares method is another application of this. If you add a2 to each side you get x2 == (x+a) * (x-a) + a2.
For example, if x=67 and a=3,
x * x = 67 * 67
(x+a)*(x-a) + a*a = (70 * 64) + 3*3
= 4480 + 9
= 4489
= 672
