3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Squeeze Toothpaste Perfectly
I've noticed that when i visit my friends or relatives houses, they always have the toothpaste all mangled up. Ultimately this is a waste of toothpaste (since you end up throwing away the rest). I've also noticed that some people purchase the more expense containers that hold less toothpaste (why would you pay more for less??) just because they think that it will make life easier~. Some other people like to go out and buy useless devices that will help squeeze out every last drop of toothpaste, but you don't need too buy something to do that!
I've always shown people how to do this method of squeezing out toothpaste because it will save you money, in the end. If you don't believe me go out and check the prices/oz per tube of the standard toothpaste tubes and the new "easier" to use tubes. You will thank me later.
Thanks to Erik Lindemann for correcting me on the bottle/tube thingy!
Step 1Starting from the End
Okay! let's say you have a regular tube of toothpaste almost empty. Your mission is to get all the toothpaste from the end, closer to the head of the tube.
Most of the time you will have toothpaste sitting in the very end, just use the corner of your sink (given you have a flat edge, you can also you a table) and the palm of you hand to flatten the tube out until you have enough of a flat end to grip.
14 comments
Sep 29, 2010. 3:40 PMAndNow4theSqueeeeze! says:
Wow Wow Wee Wah! 143
Apr 8, 2008. 8:32 AMdchall8 says:
I use the flat back of the toothbrush to squeeze it toward the top.
Apr 23, 2008. 1:55 PMcirano says:
Same here. Flat side of the toothbrush and a wall is all you need.
Apr 20, 2008. 9:18 PMtelcotech says:
Good Job, eggmix! Another way to get the VERY last bit out is to then cut the tube about one and one half inches from the cap end with a pair of those little folding scissors I keep in the bathroom (instead of a razor or exacto knife). Then I keep the now short tube closed between uses with a "bulldog" style clip (found in office supplies). For the flattening part, you can also slide a dental floss container (straight sided) from the crimped end toward the cap.
Apr 6, 2008. 11:06 PMdlregis says:
Heh... I've been using this same method myself... now I can't help but 'fix' tubes of toothpaste I come across when visiting friends and relatives.
Apr 5, 2008. 10:12 PMbruc33ef says:
Next, let's see it done for K-Y Jelly, too, and no turning on the bedroom light to do it! ;- )
Apr 5, 2008. 2:21 PMErik Lindemann says:
You were asking if it's really a bottle. I believe the term for it is "tube".
Apr 5, 2008. 9:28 PMErik Lindemann says:
No problem, man.
Apr 5, 2008. 6:34 PMxrobevansx says:
if you REALLY want to get the last bits out: slice the tube open with a razor blade/xacto knife. Just when you thought it was empty (even after squeegeeing as you have) there are at least 3 or so brushings left in that tube! Try it!
Apr 5, 2008. 4:53 PMGorillazMiko says:
I always use this method. Great job, I should have brought this to Instructables...
Apr 5, 2008. 3:28 PMw00ty32 says:
Cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:eggmix
