Step 1: Saute onions and garlic
Step 2: Deglaze
Regular cheap stuff is fine, but cooking wine is definitely not- it's full of added salt. I used a bottle of $2 Chuck from Trader Joe's, which works beautifully.
Step 3: Rice
Don't rinse the rice before adding it to the pan- you want that extra starchiness on the outside to make the rice properly sticky.
Step 4: Stock & Simmer
Stir periodically to prevent sticking, and add more liquid as necessary- I use both stock and wine. This should take close to an hour, so process the squid while the risotto cooks.
Step 5: Clean and Chop Squid
Scoop any remaining guts out of the body, and remove the thin plasticy quill. Rinse the body inside and out, then slice into approximately 3/4-1 inch thick rings.
Squeeze behind the head to extrude the beak, and remove it from the center of the tentacles. Cut just below the eyes to free the tentacles, then add them to the bowl with the body rings.
Tentacles are the best part. No, really- they're fantastic.
Collect ink from behind the eyes as well if you don't have very many squid and want to increase your ink yield.
Step 6: Season squid
Let them sit while you finish the risotto.
Step 7: Finish and Ink Risotto
You can either strain it into the pot as described above, or simply dump it into the risotto with ink sacs and all. The sacs are perfectly edible, and unnoticeable unless particularly large. I do this because I'm lazy, and if you are squicked by eating squid ink sacs you might want to reconsider this entire project.
Rinse the ink bowl with a bit of water, wine, or stock, and stir the ink into the risotto. The rest of the ink should squish out and color the risotto, turning it a purplish-gray. The flavor quite mild, and will likely disappear behind the stronger flavors in the risotto.
If you want a strong or specific ink color, start by mixing your ink into a small quantity of risotto, then dilute the mixture with more risotto until you're happy with the color. I've done this to exaggerate the inky color effect, as I actually cooked LOTS of risotto, and it would be almost impossible to get this kind of color for the whole pot without scoring a really big squid.
The remaining non-inked risotto can be finished and served separately, or saved for tomorrow's fried risotto cakes. Return your inky risotto to the stove, and cook off the rest of the liquid, and stir in a pat of butter.
Your finished risotto should be quite thick, fragrant, and inky (or not, depending on your taste), with no standing liquid.
Step 8: Pan-fry squid
Add just enough to cover the pan, and stir them around quickly with your tongs or slotted spoon.
Squid cook FAST- flip them as soon as the first side turns opaque, about 45-60 seconds, and pull them out of the pan as soon as the other side is done, another 30-45 seconds.
Be careful not to overcook them, as squid can become rubbery after more than a couple of minutes cooking. Alternatively, cook your squid for more than 30 minutes- the meat will soften, and the squid will be tasty again. I'm lazy and prefer the two-minute method, but your mileage may vary.
Flip your freshly-fried squid out onto a paper towel-covered plate to cool and drain.
Step 9: Serve
Save leftovers to dip in breadcrumbs and fry up as risotto cakes or balls. Hide chopped squid and/or cheese in the middle for bonus points.
Photo credits shared with Jess, who took all of the especially wonderful food pornography shots you see on this page.
Visit Our Store »
Go Pro Today »
I was probably raised wrong- our food had things like garlic, curry, and actual flavor.
Cool- I like squid. Put it up, and I'll try it!
Good for you! Lot's of people in the Midwest (Specially the town I live in) don't season their food well, and won't try anything out of the ordinary. I can't believe I left the Bay Area for this. (Meat and 'Taters).
The link above is for the recipe I found online. It's pretty close to what we do. There's a Spanish store online that sells authentic foodstuffs from Spain that you might be interested in La Tienda. Thing is you can probably get this stuff in your local area. La Tienda is out of L.A. I think.
Curried Squid is good too.
Squid is much better when you make it yourself- at restaurants it usually waits too long between cooking and table, and rarely tastes top-notch. So don't presume you don't like squid until you've properly tried it.
