Feeder Guidelines:
a. Feeder should be placed 10 feet away from any trees, overhanging branches, roofs, etc... anything that a squirrel could use to jump down onto the feeder. As you can see from the photo, one of my feeders is fairly close to the tree line ( ~10ft ) so it shouldn't be impossible to find a good spot for this feeder in your own yard.
b. Feeder should be 5ft off the ground, though the first feeder I setup was around 4 1/2 feet. The pole used in this instructable is 6ft tall so you should be good to go. You simply want to ensure that the squirrel will not be able to jump from the ground to the tray directly. The lower baffle has a large enough diameter that the squirrel will not be able to climb it.
How this squirrel proof feeder works:
Since the feeder should be placed 10ft away from trees, roofs and overhanging branches, and has it's tray roughly 5ft off the ground, squirrels should only have one route to get to the feeder's tray; up the pole. The baffle under the tray will be 2 feet tall and have a diameter of 6 inches. I have found ( through trial and research ) that a squirrel cannot climb up a pipe of this size diameter. Also the baffle is open at the bottom allowing squirrels to climb up into the baffle into a dark chamber where they are confused as to where to go and inevitably return back down the pole.
I cannot guarantee 100% that this squirrel feeder will work for you, however prior to using these types of feeders my yard was infested with squirrels. Now that I am using these style feeders I at most see 2-3 squirrels in the yard at a time, and have noticed that unlike other setups I have tried they lose interest in trying to get to the seed rather quickly.
Accompanying Video:
I have created a video to go along with this instructable that can be found at the below url:
Part 1: http://www.youtube.com/watch?v=3Qdm747cols
Part 2: http://www.youtube.com/watch?v=xxdxdck4Syo
Remove these ads by
Signing UpStep 1Tools & Supplies
a. 6 inch diameter stove pipe cap ( fits on outside of stove pipe )
b. 6 inch diameter, 2 foot long stove pipe
c. 2x4, ~12 inches long ( use scraps if you have them lying around )
d. 3/4 inch, 6 foot long copper pipe
e. 16 inch diameter plant pot base ( can use other size )
f. 8 - 2 1/2 inch #8 deck screws
g. 4 - 1 inch #8 screws
Tools Needed:
a. miter saw w/ miter box ( can do without box )
b. power drill
c. 7/8 inch spade drill bit
d. 3/16 inch drill bit
e. center punch
f. hammer
g. work gloves
h. tape measure
The tools and parts should be fairly straight forward. The work gloves are recommended when putting the stove pipe together as the seam is fairly sharp and can cut your hands ( it happened to me ).
anyways, good idea - let me know how it works out if you try and make your version.
Cheers,
Morgan
