3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Squirrel Proof Finch Feeder
Some friends have had several finch feeders wrecked by squirrels over the last little while. The two they showed me were made of wood and clear plastic. The holes for the seeds are quite small (~2mm), but the squirrels would chew them to something more like 5cm and clean the thing out. When I saw some venting pipe at the hardware store that was about the same size, I figured I'd challenge the squirrels - they are 50km from here so I have no revenge to fear.
Step 1Parts
Parts
Supplies:
- 2 feet of 3 inch vent pipe
- 2 end caps
- about 1 foot of wire (ideally same material as pipe, or covered)
- rivets (sheet metal screws would do)
- 2 about 1 foot pieces of cable (or a dowel)
- 4 zip-ties
Tools:
- A drill (you might be able to punch through the metal with a nail instead...)
- drill bits of the size for your rivets ot to pre-drill for the screws, if needed)
- a riveter (or screw driver if you use screws)
Substitute as McGyver would.
5 comments
Jan 31, 2009. 11:51 AMcriscormier says:
thats good if you want to give your backyard birds a little bit of galvinise!! poisoning!!! , after a few rains that thing is gonna be ugly as f**k, good prototype but may want to consider using stainless steel or wtv can stand up to the elements!!!
Feb 1, 2009. 5:08 AMSox says:
MyDearFellow,
I am not sure what you thought was involved in the process of galvanization to provoke such an outburst! There is no need for profanity, even if you do mask it with '*'s.
In a nutshell, galvanization is the process of coating steel or iron with a thin layer of zinc to prevent corrosion. You can read more about it here,Galvanized steel but I can assure the galvanized metal will withstand the elements for many years to come.
Jan 31, 2009. 7:48 PMScott_Tx says:
Galvanize poisoning huh. That's a new one.
Jan 30, 2009. 8:39 PMNorthernSuze says:
So far my squirrels are winning! I have had two "squirrel proof" feeders shredded. I have used a glass juice bottle laid on it's side with some success; the smaller birds can enter and the squirrels are thwarted. I will be looking through the garage supplies to try your idea. Although for the fun my long-haired mini-dachshund gets exchanging insults with the seed thieves I will make sure they get their fair share, too! Suze
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:berserk
