loading
Step 4: Step 4 ~ Remove Shamrock stickers & bake to heat set
To remove the shamrock stickers, simply peel them off. Once dry the
shamrock stickers are removed you will see the shamrock shaped outlines on
the clear glass and standout against the frost green paint. A very cool effect!
Clean the paint tray and sponges with easy soap and water clean-up. Let the
frost paint finish dry and cure for at least 24 hours before heat-setting. As the
paint dries you will see the frost effect become visible and the shamrock
shapes pop out!
Once cured and heat set in any domestic oven, the glass items are scratch
resistant and dishwasher- and-oven-safe. Place the painted glass items in a
cold oven and when the temperature of the oven has reached 325 degrees F
(160 degrees C), bake for 40 minutes.
Once baked, the colours and items are fully cured. Remove the glass items
from the oven using oven mitts, and let them cool before handling. Your little
leprechauns will be thrilled to see their creations completed.
Place a pillar candle at the center of the glass planter lantern, put on your
leprechaun hat and cheers!
Happy Creations
http://maddylanephotography.zenfolio.com/
Good idea It's&nbsp;beatiful<br />
About This Instructable
5,002views
12favorites
Bio: I'm a decor designer and photographer, Quebec, Canada
More by imakeit:St Patricks Lucky Charm Creation Sweet Curry Summer Rice Salad Recipe The MIY $5.00 "All Dress"  Make it and wear it, From Spring to Fall
Add instructable to:
