Introduction: Stable Oven Skewer
Oven tray that keeps food up right so that it can be cooked evenly
Step 1: What You'll Need
1 Broil Pan Set
2 3/32 Ferrule and Stop Set from Home Depot
1 Gorilla Glue
3/8 inch screw
1 Drill
3 Skewers from the Dollar Store
3 regular upholstery tacks
Saw (optional)
Hammer (optional)
Step 2: Remove Skewer From Handle
-Pull apart metal rod from wooden handle
-if difficult use saw to cut them apart
-set aside for later
Step 3: Creating Holes
-Drill three holes along center of lid with electric drill
-make sure the hole goes all the way through the lid
Step 4: Cleaning Up the Holes
-Use a hammer to lightly make sure holes are flattened
-its important that the surface stays flat for next part
Step 5: Create Stoppers
-take out pointed end of tack and keep the base
-take 3 ferrule's from the home depot set
-glue ferrule to base of tack
-these will turn into "stoppers"
Step 6: Block Holes
-glue stoppers to the bottom of the lid where the drilled holes are
-make sure to align ferrule with hole is to create extension for skewer
Step 7: Add the Skewers (final Step)
-take the skewer and place it into the holes
-should slide in with no problem
Step 8: Video
Epilog Contest 8
Epilog Contest 8
