3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stackable Ambient RGB LED Cube Lights
Step 3Cube Construction
Cube Construction
Hot gluing the sides
Basically we want to start by connecting the first tile to the second by applying two decent dots of hot glue to each corner as we go. continue this process until you have reached your last piece. Once you get the hang of this it won't take you long.
Attaching the base
How you attach your base will very much depend on what tiles you were able to obtain. I only run mine for limited amounts of time so I choose to simply use small dots of hot glue to attach the base. When you need to change batteries ease the base away. The glue will release as long as you don't go over board.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
94
Author:Lftndbt
I work in a D.i.Y style superstore. I am not sure if that is a good thing or not, but it certainly perpetuates my interest in such areas. I enjoy high powered devices of any kind. I do not give...
more »
