Stacked Cardboard Headphone Stand
4,324
123
6
Published
Introduction: Stacked Cardboard Headphone Stand
this is how I made a stacked cardboard headphone stand for a pair of shure SRH-750DJ headphones. I made some pdf templates of the shapes I used for the different layers. a smaller set of inside layers allows the cable to pass through the stand if desired. I made the stand over two sunday afternoons, the body of the stand one afternoon then added the decorations the next week.
Step 1: Gather Materials
To make this stand you'll need some simple materials
cardboard
I used the double corrugated cardboard from a couch shipping box. any corrugated cardboard will work, the number of layers you will need to cut will change depending on the thickness of the cardboard you use
marker
for tracing the templates onto the cardboard, I just used a fine sharpie
knife
to cut out the cardboard, any small craft knife will do. you could also use a band saw if you have one. I used the small blade on my swiss army knife
glue
for gluing the layers together. I used the cheapest white glue I could find
template
I've made some pdf templates you can cut out and trace. the one included with this step contains all the possible lines you will need. on each step I've included pdf's of the shapes you'll need for the step. The pdf's are for A4 paper, if you're going to use letter sized paper you'll need to adjust the printout. The template should be 24cm long
Step 2: Cut Out Layers
cut out the paper template and trace it onto your cardboard. make sure the center line of the template is aligned the same way with the cardboard on each trace. I found it easiest to line the center line of the template up with one of the ridges of the corrugation. using double corrugated cardboard I needed 6 outside pieces and 4 inside pieces, you might want to double that if you're using single corrugated cardboard. once they're traced onto the cardboard carefully cut them out with your knife. I found it best to cut out the bottom half of each outside piece first then go back and cut all the top halves, it kept the integrity of the sheet better and made cutting the bottoms out easier. if you're careful and lay them out well you can even get an extra piece of wall art with the project =P
Step 3: Glue Layers Together
spread your glue over the surfaces of your pieces you want to glue together then set some weight on them and let them dry. I split my outside pieces into two equal groups and glued them together along with the inside pieces then glued all three sections together once they'd dried. a trick to making the glue up easier is to put the feet of the stand against the wall when you glue them so they're aligned with each other. if you were exact with your tracing and cutting it should make it easy to have the tops and sides aligned too. just try and do your best to make them as aligned as possible, if it comes out of the glue up worse than you'd like you can get some sandpaper and sand the edges smooth, the cardboard sands pretty easily.
at this point your headphone stand is functional! all that's left is to decorate it a bit!
Step 4: Add Decorations
use the templates again trace and cut out the decorations for both sides of the headphone stand. I used single corrugated cardboard for the decorations. you can glue a sheet of white paper to some of the parts to add some contrast. I used the cut out templates to see how paper would look on the different parts. I chose to make the base and 2nd layer of decorations white. glue the decorations on as if they were more layers to the headphone stand and then you're done! you could sand it, paint it or add different decorations as well to get it looking the way you'd like
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    6 Discussions
    Incredible project, I made it with wood. Thanks for sharing
    16 21:26.jpg16 21:26.jpg
    Did you build it as a stack or did you build the front and back pieces then use thin cross pieces of wood?
    Thanks, yours looks great! nice improvement with the cord wrap on the back!
    Absolutely fabulous design idea! Now I just have to figure out how to make one for EVERYONE in my family....
    Beautiful design. And i have the 750DJ too!
    Very cool design!
