3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stainless Steel Garden Incinerator - Patio Heater from recycled scrap.
Project:  To build a replacement for the ugly rusted and burned out oil drum we have been using for a incinerator.
Lets face it when it come to recycling we all end up with bio mass that unless you live beside your recycling plant just become a nightmare to get rid off, my nearest center is 5 miles away in a different council district, the one I should be using is almost 12 miles away so anything that I can safely burn gets burnt.
I wanted to make something that would do for burning paper cardboard and garden waste. but would be nice enough to be used a heater.
We have been using an old 45 gallon steel drum as a make  shift incinerator which is almost burned out and rusted to bits. its good point was it had a large capacity for burning, but this was also its bad point was that the large capacity meant you just bunged big stuff in and it tended to go out as it was badly loaded or be very smoky.
I had an old washing machine rusting away in the yard that was due to go for scrap, they have stainless steel drum that well ventilated and look nice and make a perfect incinerator as stainless steel will not burn up like a steel barrel will do over time.
The washing machine drum has a smaller but reasonably good capacity, this will mean it must be loaded better and should hopefully burn much better.
This is a simple and easy project to build if you can scavenge the parts.
UPDATE: Some people have asked what type of washing machine has the stainless steel drum, they are found in the front loading automatic machines. I have added a pic to step 1 of the next victim to be gutted from parts. I will do a detailed instructable of what fab and groovy stuff is to be found in them.
If you cant find a washing machine a tumble dryer should also have a stainless steel drum that will do, it will probably have a larger capacity also.
Materials used.
Stainless steel washing machine drum.
1" galvanized tube (scavenged from an old farm gate)  20 x 6mm flat steel could also be used.
The rim from an old bike wheel.
M6 nuts, bolts and washers.
Self taping screws.
Thanks for looking and i hope that this gives you some ideas for your own design.
Andy.
PS. I didn't plan this out, it was a case just wandering around the yard and sheds and using what ever turned up.  So it just kind of happened, sometimes that kind of approach works just as well as the long drawn out plan.
Step 1Preparing the drum.
Preparing the drum.
You will need to find a busted up and scrapped Automatic washing machine that is a front loader.  Or if you cant find that a tumble dryer should also have a stainless drum.
I gutted the stainless steel drum from an old washing machine that is due to go for scrap.
I used a hand axe to crudely hack the drum free form the plastic tank it is mounted in, this was my quickest option rather and undo just way to many screws.  what ever you choose to do be careful as fingers and eyes don't grow back.
Once the drum is free, you will need to cut it free from the aluminum casting that houses the bearings.  The drum is riveted to the aluminum housing at 3 points they will show no resistance to a angle grinder.
114 comments
1-40 of 114next »
Jul 22, 2010. 6:57 PMrimar2000 says:
With that washing machine drum you can make a MCG (Macro Chease Grater)!!
Jul 23, 2010. 1:57 PMbilham says:
I inherited an old 50's era washer with my last house. I salvaged the bakelite agitator and made a very cool lamp out of it.
Jul 23, 2010. 5:19 PMrimar2000 says:
There are some of these that are horn shaped, I did a very good passive megaphone with one of them. It was so good that was stolen at the first use...!
Jul 25, 2010. 6:58 AMdeni2me says:
I think this looks way cool! Great idea!
Jul 26, 2010. 4:10 PMDr. dB says:
However, where do we find a capacity conversion chart from "pounds of laundry" into "pounds of cheese"?
Jul 26, 2010. 4:17 PMDr. dB says:
Yep! Although the newer designs are probably more efficient and/or effective, the old styles were often MUCH more elegant and decorative. The one I tore out of Mom's washer back in the early '70s (also a 1950's washer!) was about the same shape, but white ( well, off-white after several decades of dirty duty up against four kids and any number of pets...) I think the black one makes the more fashionable lamp, although white-ish might scatter (agitate?) the light better...
Aug 3, 2010. 5:48 AMBlackSheepBrit says:
Saw this pop up in one of my RSS feeds the other day and remembered I just happened to have an old washing machine lying around and decided this was the perfect project for me and my boyfriend. After several hours of getting the damn inner drum out we could all finally sit back and marvel at our shiney new fire bowl. We made the base out of what was actually attached to the outter drum - just flipped it over and voila..perfect! Not only that, it's spins around too - pointless but cool!
Aug 4, 2010. 3:01 PMBlackSheepBrit says:
Hopefully it's added a pic this time!
Aug 5, 2010. 3:12 AMBlackSheepBrit says:
I'll let you know when we finally get a chance to try it out. Very excited though, awesome idea...keep em coming!
Aug 5, 2010. 1:54 PMsgsidekick says:
That is so cool!! lol. And it came with its own base!!! You lucked out!
Sep 21, 2011. 11:46 PMUnindoctrinated says:
I made one of these many years ago specifically to be used as a small fire for people to sit around. (Some people call them fire-pits but as it isn't a pit or even a brazier I've never really been sure what to call it). Anyway, unfortunately it was a total failure for that purpose, it feeds too well. As an Incinerator it is incredibly effective. The holes almost seemed to be coincidentally or accidentally arranged in such a way as to provide maximum Oxygen supply. I'm pretty certain that if mine had been made with a lesser grade of steel it would have melted. One night I burned thirty or more three inch by fourteen inch logs in about five hours. Great incinerator though.
There are probably different brands or models that have a more suitable air-flow for my purpose that I haven't found yet but the one in this Instructable looks very much like the one I made. If the OP ever reads these comments I'd be interested to know how he/she feels theirs worked in that regard.
I made a small plant pond out of a Tumble-Dryer barrel that is still in my backyard, still holding water, twelve years on.
Apr 2, 2012. 4:04 PMUnindoctrinated says:
I took the barrel from a tumble dryer which only had holes in the centre of the back so I took the bulbous window from the door and siliconed it to the inside to cover the holes, buried it in my garden, filled it with water and put three plant pots in it with marsh type plants. They have thrived and as it is mostly in the shade it rarely needs topping up.
Sorry, unfortunately It is so densely surrounded by plants a photo would be pointless.
Mar 27, 2012. 3:05 PMOCMichael says:
I am fascinated by the idea; it occurs to me that the opening in the top would be able to accommodate a nice, heavy-guage Stainless Steel Salad Bowl, perhaps with some brackets to suspend it to allow smoke from the firebox to escape. Place some well-soaked aromatic wood in the salad bowl and set up some ducting and you would be well on your way to creating a nice, high-capacity Barbeque Smoker. Any culinary "Mac Gyver' types out there interested in giving it a try? If you do, please let me know how it works out! <GRIN>
Nov 4, 2011. 11:28 AMkkeely says:
I used mine last weekend and it held up fine. The only issue is that 90% of the heat went straight up. Any ideas on how to "deflect" the heat outward? Or make it radiate more heat?
Sep 21, 2011. 3:11 AMBlue Velvet Chair says:
Great repurpose project. Featured it on my blog today (blog focuses on repurposed and recycled projects). Have a look if you get a chance. Would love to know what else you have.
Michael
http://bluevelvetchair.blogspot.com/2011/09/whats-that.html
Sep 21, 2011. 3:09 AMBlue Velvet Chair says:
Love the project! Included it in a post on my blog today for repurposed washing machine drums. Have a look - my blog focuses on repurposed and recycled projects, so I'd love to know what else you have.
Michael
Apr 29, 2011. 6:36 PMtyep says:
Here is mine. I showed up at the dump, and someone had already dismantled a dryer and left the drum laying there, so I scooped it up, grabbed a refrigerator rack for the top, bolted on some tent poles for legs and it's working fine.
Jun 19, 2011. 6:23 AMLittlestWorkshop says:
My Dad used to repair industrial washing machines and dryers and for ages we had a giant drum at the bottom of our garden, it has made a fantastic incinerator over the past few years, I just put it on some bricks, if the wood is dry it burns super hot and you don't get any smoke at all really.
Apr 7, 2011. 10:53 PMasteadman says:
Love it!
Local repair shop gave me a dryer that was too far gone for them to deal with.
Tore it apart today and got myself a new fire pit in about an hour.
The drum housing was weighted with some monster sized lead weights. Made for a great temp base to hold the pulley assembly (now "stand") until I decide wear it's permanent home will be.
Thanks for a great project!
Jan 3, 2011. 6:52 AMlovejasmin says:
"Fingers and eyes don't grow back", ahhh, should be a slogan on the next OSHA workplace safety posters. *tips hat*
Jul 22, 2010. 4:52 PMsneaky snake says:
As far as green goes this is way worse than recycling. But I'm not against burning but you live 5 miles from a recycling center, good god, that is your next door neighbor. And last time I checked, pretty sure they stop by your house to pick it up for you. Anyways, all criticism aside, I like your Instructable, especially the spontaneity of it. Good job
Nov 18, 2010. 8:45 AMnabo00o says:
I agree with everything you say here, one has to think practically about the total benefits the present disposal methods gives. And using gasoline to reduce emissions is not logical, except of course there is a limit were you can gain if its close enough....
But, about methane, although more powerful than CO2, will not stay in the atmosphere nearly as long. And in colder regions (like here) methane isn't as intensively produced as say close to the equator (I see you mentioned that).
If one has the space and could use it, organic waste makes for perfect fertilizers and benefits the soil it is mixed in. I guess it all depends on the needs and whatnot.
So, 'ideally', I would have separated the stuff that's too wet and the stuff that's dry enough to burn, but it all depends.
Conclusion: Self sufficiency is great and green!
Jul 31, 2010. 10:47 PMamugno says:
Are you on crack????
Jul 26, 2010. 4:25 PMDr. dB says:
If your local “official” recyclers are composting and allowing the methane to escape, you're quite right - and they are worse than fools. Any PROPERLY designed facility will capture, compress and use that handy by-product to fuel some of their on-site heating and other small flammable-gas-consuming systems. Of course, at home, on a small scale, it would be challenging to achieve, if possible at all… Anybody done an Instructible on that?
Jul 29, 2010. 11:37 PMDr. dB says:
Too true! I live in the northern, midwestern USA and, although this time of year it's oppressively hot, there are still several winter months during which it surprises me that septic systems can actually still function when the whole world seems like one huge ice-cube, right down to the magma...
Jul 23, 2010. 7:31 AMwfp2a says:
I appreciate your analysis of the situation but I have a question (I am not trying to be smart...maybe just trying to get a bit smarter). You mentioned that the burning process is carbon neutral because burning paper only releases what the plants had already extracted from the air...I don't want to nitpick but what about glues and whatnots that go into the paper when it is made? Honestly, I know nothing of the paper making process but I figure there has to be something else in there but plant fibers. Typical paper is not purely organic I suppose. Just curious on your thoughts...
1-40 of 114next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
118
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
