3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stainless Steel Rose from Scrap Metal
This is a rose sculpture I TIG (GTAW) welded at school. It is made from left-over stainless steel scraps that were straight off the shop floor at my school welding shop. I believe this project embodies the topic of this contest in a few ways. The first and most obvious being that it was completely constructed from scrap metal. And not just typical scrap...the scraps in our shop go through a series of re-uses until they reach a size that is no longer easily used in class and is then shipped to the scrap yard for recycling. I made sure to grab the majority of my scraps from the end bin to make sure the scraps had been re-used as much as possible before I began building with them. Secondly, the topic of my piece is a rose which is an embodiment and symbol of nature's beauty. I dedicated roughly 55 hours of shop time to obtain the final product to replicate that beauty as closely as I could. Lastly, the material I used for the project was stainless steel. I did this to give the final piece a certain level of complexity both visual and inherent. It stands as a icon that something as industrial as steel can be used to create one of nature's softest, most stunning symbols. It also shows that this relationship between industry and nature can be renewable and sustainable...hence the "Stainless" aspect of it.
Step 1Equipment & Materials
Equipment:
- TIG (GTAW) or MIG (GMAW) Welder
- Stationary Belt Sander
- Bead Blasting Cabinet - Optional
- 4 1/2" Angle Grinder with Abrasion/Cutting Wheels
- Bench Grinder - Optional
- Metal Work Bench to Attach Ground Cable
- Bench Vise
- Ball-Peen Hammer
- Vise Grips
- Sheet Metal Sheers
- Dremel Tool with Grinding and Polishing Bits - Optional
- Typical Welding/Fabrication Safety Equipment
Materials:
- 18, 20, or 22ga Stainless Steel Sheet Metal Scraps
- 1/4" Bar Stock (Round or Square)
- Stainless Steel Filler Rod (for TIG)
- Stainless Steel Electrode Wire (for MIG)
161 comments
1-40 of 161next »
Feb 24, 2012. 1:16 PMMIGDHORSE says:
loved your tutorial. here's my version. not quite as refined. i wanted it to be a close replica to a rose i had in the shop. so i folded some of the petals to make the classic point you see the petals making once the rose starts to die. i only have a die grinder and a bend grinder and some pliers and a millermatic 180 220v. i spend probably 15-18 total hours. 23 pieces in the bloom. and various other pieces. i couldnt get my thorns quite as nice as yours though, i plan on using a dremel to shape them next try. thanks again for your awesome tutorial.
Apr 24, 2010. 5:35 PMiloveairsoftstuff says:
wow. you must have a very nice girlfriend to do that.
May 30, 2011. 5:05 PMRoflolommo says:
omg same thing happened to me. I think metal flowers are cursed.
Jan 9, 2012. 1:57 PMelectridanger says:
they are cursed...I made one out of thin sheet copper...I left it for her and talked to her later and she said that she didn't want to date...although I felt it was that she didn't want to date me...I didn't take it back though...
Sep 12, 2011. 3:02 PMlance_r says:
I made my girlfriend a metal rose and gave it to her she liked it so my next project I made a sculpture with her name for christmas.. She broke up with me before I could give her the sculpture so I took it (the sculpture that is) to the back yard with a sledge hammer and vented a bit. The following day I brought into class and plasma torched the crap out of it hahaha
Dec 12, 2011. 4:42 PMxxMelxx says:
Very Beautiful! I Will Try Making One This Week As A Christmas Gift For My Grandmother Hope It Turns Out As Nice As Yours :) I Already Made A Daisy-Like Flower In A Pot But A Rose Just Seems Alot More Challenging .
Nov 13, 2011. 4:37 PMNawaz says:
By the way, you could use some polishing compound and a small buffing wheel to give it a shiny look :)
Nov 13, 2011. 4:34 PMNawaz says:
wow..nice..was planning to do something similar. Got a better idea about how am gonna do it now..thanks for sharing..very nice instructable :)
Oct 6, 2011. 7:07 AMRocketManDave says:
Reminds me of the end of the film "District 9".
Jul 26, 2011. 12:56 AMes30381 says:
hey mate, excellent instructable..... really informative. can i please just ask the approximate sizes of your largest and smallest petals and leaves and petals and stuff. thanks mate, it's a huge help. ES
Jul 26, 2011. 11:07 PMes30381 says:
thanks mate, huge help.
Jul 22, 2011. 9:24 AMrjasso says:
hers mine
i used a flux core mig welder to weld them together
Jun 25, 2011. 9:37 AMcmetals says:
here is my take on the stainless rose
Feb 15, 2011. 5:56 AMduboisvb says:
Thanks for the instructable. I made the attached rose over this past weekend for my wife for valentines day. It is not nearly as polished as yours but it turned out ok and it was fun to do.
May 25, 2011. 5:15 PMJRG1 says:
Nice stuff.I am new here and here is a rose that I made recently.what ya think?
May 23, 2010. 5:19 PMhottamaleindustries says:
Would this work with copper?
Jul 2, 2010. 12:58 PMD$ says:
maby although you would need some serious equipment and if your not carefull the copper will turn grey from heat i've only done some copper and im pretty sure the only way you can weld it is tig
May 14, 2011. 3:14 PMvlxwgn says:
You can silver solder copper fairly easily, however you will either need to try and solder the entire bloom together at once or get different levels (pure, sterling, enameling, hard, medium and easy... from highest heat required to lowest respectively) of silver solder that melt at different heat, the inner most would use the highest heat and the outer most would use the least in order to stay together as you were building it. other than that the tools required would be far less expensive.
Jan 11, 2011. 6:27 PMArron199 says:
I made mine in under 3 hrs, but im a boilermaler by trade. Using tin snips to cut the material saves a huge amount of time, $18 an hour!!?? Where in the world is that considered ok for this type of work? Dont mean to offend anyone but artistic metal work earns you no less than $40ph here :s
Anyway, awsome instructable and nice finnished product.
Mar 25, 2011. 1:10 PMMetallication says:
Thank you so much! This was an awesome and fun instructable! I will give it to my gf for her birthday next month! This is my first year working with metal in school, and I didn't have much cash, so I found YOU! It was all scrap 22 gauge sheet metal. It took me roughly 15 hours total to finish it. I painted it with a metallic silver when it was finished. Thank you again!
Mar 25, 2011. 1:13 PMMetallication says:
Oh, and here it is.
Mar 7, 2011. 7:34 PMbreber says:
Ive actually made a rose like this.. but the steps to create it were different. still good work on the rose.
Feb 5, 2011. 11:21 PMMrRodrigez says:
hmm has anyone thought to hit the budding petals with an OAW torch with no oxy to give it a black coating, then clearcoat it?
Apr 29, 2010. 2:06 PMpedla says:
Very nice and way beyond my ability and access to tools. Do you consider selling them? My daughters middle name is Rose
Oct 25, 2010. 5:48 AMGazmanDay says:
i am looking into buying something like that as a gift
if i was to ask you to make a few to order lets say six
how much would you charge for that and i would be willing to cover p&p
if your up for it please let me know
Apr 29, 2010. 4:17 PMreoga13 says:
 you should try making one using the techneque the other guy uses...and that i wuse which is coat a real rose with a metallic powder that you make into a paint like substance and then electroplate it
May 12, 2010. 8:40 AMpedla says:
jaredzeuli I agree that electro plating or any other form of process would destroy a fragile flower. But I still thank reoga13 for response with what may have been helpfull info.
 Also I thank you for the possibility of buying a rose from you for my daughter, but i think the time that you must spend on making these and cost of materials added to transport to Australia, with me attempting to pay from China where i currently am would make this unfeasonable
  Thanks and keep up the good work, if you come up with other ideas then please post them. CYA from Aussie PETE
Apr 30, 2010. 10:20 AMpedla says:
 Thanks for the response reoga13 but I do not know who or what process you suggest. More info please cheers.
Apr 30, 2010. 8:06 PMreoga13 says:
 the methid that this guy uses for the iris seed pods
www.instructables.com/id/Electroforming-an-Iris-Seed-Pod/
1-40 of 161next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:jaredzeuli
