3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stainless Steel Rose from Scrap Metal
Step 3Forming the Petals into the Rose Bloom
  • last photo ←
After the parts have been shaped you can move on to forming them.
Petals:
Basically, you start by folding two of the smallest sized petal pieces in half so they resemble the shape of a hot dog bun. Then slide the edge of one piece into the center of the other piece and crimp them together in a vise. Now you have your starting point to begin welding. From this point on you have to form each piece so that it 'hugs' around the core that you just started. After you have shaped a petal you can weld one side of it to the core and then if need be, you can bend it to perfectly fit the contour of the core. Once you achieve the desired shape, weld the other side. Then bend the pointed part of the ice cream cone shape inward to form the bottom of the rose bloom, weld it up, and grind smooth. After each pedal is welded onto the core make sure to grind or sand off the weld beads to keep the rose tightly packed. Once you start getting a couple layers away from the core you can begin creating the 'lip' along the top of the petal. This gives the rose an opening effect visually. I won't try to describe in words all the techniques for obtaining all the contours because it would sound confusing. Just use your vise, vise grips, ball peen hammer, and work bench and get creative! By trial and error you will get the hang of how the metal behaves. Just remember that the good thing about working with metal is that you can always fix a mistake and no one will ever know the difference. Remember to alternate locations of the pedals to avoid making the rose look like a spiral. Once you have gotten the rose bloom to your desired size just weld up any gaps in the bottom and sides, grind them clean, and move on to the stem.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:jaredzeuli
