3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8 Ft. Tall Stalk-Around costume
Step 7Costume head: wooden mount
Now that the arms and framework are finished let's move on to what I think is the coolest part of the costume, The working head movement, To start you'll first need to make a wooden head mount that fixes on the camera tripod, I made mine by simply cutting a piece of plywood into a circle a little bigger than the foam head's neck base (this was all done by using a rotozip) I then found the center of the circle and drilled a small hole so the camera tripod could screw snugly into it, I then made two additional holes and attached a miscellaneous fitting I found to work as a foam head support. I had to cut some pieces out of the head to make it fit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:gogglecrab
Anytime there's a cap, spring, screw, bottle, hinge, LED I ponder on what I should craft the little trinket into! I like to turn everyday situations into an opportunity for creating, Turning the ordin...
more »
