Stand Alone CD Player
 by MrJentis
Featured
This is the follow up project from my cd player adapter project I did earlier to make a stand alone cd player. Other computer recycling projects I did were the Case/Safe and the EPFU.
Step 1: Tools and Materials
This is my version of how to make a stand alone cd player using your old and useless computer case.
Here's a bunch of things I used to build mine and you'll probably need:
Tools
  • hacksaw (to cut the sheet metal)
  • electric drill and various drill bit sizes
  • bench vice
  • Phillips screwdriver
  • metal file
Materials
  • an old computer case (preferably with both doors)
  • wooden planks of various sizes
  • cardboard box
  • paint i.e, (spray paint)
  • lots of screws
Of coarse, to build a functional stand alone cd player, make sure yours has a play button and a headphone jack and volume knob if you want to use the front part. To get audio at the back of your CDROM directly to your computer speakers, you'll need the audio
cable that plus into it and a 3.5mm audio jack.
deeppu says: May 15, 2013. 5:12 AM
how you make the circuit? plz upload photo of circuit because i am confused.
pvtrobertearl says: Nov 4, 2012. 3:26 PM
Could I uses a power supply from an on computer to puwer the cd drive to play through speakers
MrJentis (author) in reply to pvtrobertearlNov 4, 2012. 4:39 PM
Yes you could, that's if you don't mind the cumbersome bulk it adds.
profpat says: Aug 27, 2012. 7:27 PM
nice project!
lacking is the amp for the speakers..
profpat in reply to profpatAug 27, 2012. 7:41 PM
something like this, which i assemble using prefboard and two tda2002 ic amplifiers - 12volts d.c. 5 watts output per channel..
MrJentis (author) in reply to profpatAug 29, 2012. 6:29 PM
That's a nice amplifier you've made there, but it wouldn't work with the laptop charger I used in my setup because it was just barely enough to power the CDROM and nothing else. Besides, my design was as simple as possible and used the computer speakers as the audio output which already have a built-in amplifier and volume control. An additional amp along with the CDROM and bigger speakers would have required a beefier power supply which would most likely need a large and heavy transformer and not as compact as a laptop charger. I hope you see what I'm getting at here...
profpat in reply to MrJentisAug 30, 2012. 1:18 AM
thanks,
btw,
this amp will work with just a 12volts 1ampere ac-dc adapter/charger, i know laptop charger gives around 19V- 3.49amps and above..
sroy5 says: Aug 27, 2012. 4:01 AM
good post & thnx .I wl try it soon.post more pc component recycle tute.
Nicola Tesla says: Aug 18, 2012. 5:00 PM
To complete this geek set, you must have HDD speakers! I hopefully (If i don't forget) will have a picture of my setup with some hdd speakers!
emerson.john in reply to Nicola TeslaAug 26, 2012. 6:17 PM
What are HDD speakers?
MK3424 in reply to emerson.johnAug 26, 2012. 12:55 PM
these: https://www.youtube.com/watch?v=wXeM4ELHNqQ&feature=watch_response
emerson.john in reply to MK3424Aug 27, 2012. 4:37 AM
Thanks for the link, that's a good trick! Back in the old days of computer service the linear motor that drove the head stack was sometimes called the actuator, sometimes the voice coil!
farna says: Aug 26, 2012. 5:20 PM
With a USB to IDE adapter added you could use a small single board computer like the relatively new Raspberry Pi (http://www.raspberrypi.org/faqs) to add juke-box and video features. Would be nice little multi-media device then, and kept to the size of two cd-rom drives even with power supply built-in. Has TV output as well as HDMI, though I don't know if it's powerful enough to do HDTV decoding. Of course you could go all the way with a full featured SBC like this -- http://www.embeddedarm.com/products/board-detail.php?product=TS-7800 -- or maybe a mini ITX board. At 6.7"x6.7" (170mmx170mm) it's a bit big though (the SBC in the link might be a bit too big as well, couldn't find the size in mm or inches, just in "mils".
DrizzleFrizzle says: Aug 17, 2012. 8:55 PM
it would be cool with a monitor so it could play movies
al_packer in reply to DrizzleFrizzleAug 26, 2012. 3:13 PM
They have something like that--it's called a "laptop".
Wyle_E in reply to DrizzleFrizzleAug 18, 2012. 10:59 PM
To drive the monitor, you need the video subsystem that's usually part of the motherboard, so you might as well get an obsolete computer. You don't need much RAM and you can run one of the smaller Linux distributions. Not using Windows lets you use a really cheap machine that has been wiped before being junked by a corporate office, since the corporate mind regards a computer without Windows as waste.
e5frog says: Aug 26, 2012. 10:59 AM
It would be fun to be able to use the kind of drive that only has the eject button - control it through the IDE interface.
Nicola Tesla: Why HDD speakers, don't they sound like crap? ;-)
aamin5 says: Aug 26, 2012. 10:09 AM
wow, sheer bad luck...i just gave my old pc away for recycling 4 days ago...wish i had seen this before!
Nice fun little project, kudos!
amandaghassaei says: Aug 17, 2012. 10:14 AM
cool project! how hard is it to find a comp cd player with the control buttons still on it?
MrJentis (author) in reply to amandaghassaeiAug 17, 2012. 10:21 AM
funny you should ask. I have a few that doesn't!
randofo in reply to amandaghassaeiAug 17, 2012. 10:20 AM
Not too hard. I have a box full of them. I'd say about 1 in 4 drives you pull from an old computer has this.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
