We built this planting workbench out of shipping pallets! Enjoy this visual how-to and go to our blog to get an even better understanding of what we did and why!
Here's what you'll need:
•Power drill and drill bits
•Saw
•Screws (heavy duty, outdoor screws. Pallet wood is really hard)
•Nails
•Hooks
•Five shipping pallets
•Vinyl cover
•Tape measure
•Hammer
•Crowbar
•Level
Step 1: Deconstruction
The first step is deconstruction, break two of the pallets down to individual planks.
juanangel says: Jul 24, 2012. 5:40 AM
It is a great looking design. Now, if you place the rear pallet horizontally you will be able to place removable hangers or even shelves for more space.
myhomelifemag (author) says: Jul 24, 2012. 1:14 PM
Very true! The only reason we chose not to go that route is we needed something to screw into place. If you rotate the backing just 90 degrees there is no siding.
To make it work you'd have to put an additional piece of wood in between the top and bottom layer giving you something to screw securely onto the table top. We chose to indulge those extra few steps and utilized the plank that was already in place.
For someone slightly more ambitious I think they'd be a great idea! You wouldn't be limited to hanging things that fit on your bolts and would have a little more freedom in organizing your storage.
Thanks very much for stopping by and leaving us your thoughts!
will1947 says: Jun 27, 2012. 1:28 PM
I notice in the de-construction picture you are using a crowbar and I would like to make a small suggestion?
I use lots of old pallets in my garden and workshop and over many years I discovered the ideal way to de-construct the pallets without splitting the boards which is what happens when you use a pry or crow bar. By using to use a jig saw with a metal cutting blade to cut the nails and later knock the remains of the nails out with a pin punch or centre pop. I have since progressed to a B+D scorpion saw or you could use a sabre saw all of which have longer and more flexible blades than a jig saw.
I have made all sorts of planters fencing etc. over the years from this free source of wood.
Nice instructable but a bit big for my patch of greenery.
myhomelifemag (author) says: Jul 24, 2012. 1:10 PM
Thanks very much for your thoughts! That's a great suggestion and one that we had considered. Unfortunately, the proper saw was not in our workshop and we thankfully had no problem prying the boards apart with hammer and crow bar.
If we built this again, we'd make sure we had the proper machines to deconstruct for us. That was definitely the biggest struggle during this project.
The right tools make all the difference.
Thanks again for your encouraging words!
EvilDefman says: Jul 22, 2012. 12:24 AM
That's a good idea. Pity it was too late for me, though.
A few years ago I went on a three-month bender, driving around and taking pallets, no matter what. Then I tore them apart, using small crowbars and hammers and I mess my shoulder up. Since then I hardly worked hard, in deference to my shoulder, which is frustrating. I want to do so much.
This neat simple idea of cutting the nails off is neat, but what I figure is a better crowbar, ones with pneumatic lever in it, of some sort. Haven't been able to figure it out. Doesn't matter.
By the way, i found that StemEnhance worked in healing the shoulder to as near-new as possible, and that means five bottles of StemEnhance over a five-six month period. I was lucky I found it. My shoulder still gets sore now and then, it aches sometimes when I use it for something heavy.
So don't wack and hammer the boards, the nails are like GLUE... and I did it for THREE months, now that's a lot of shocks to the shoulder, weakening it and then it burns, somewhere inside... burning and burning and burning... it was tortore and I kept going, wanting to finish building the pallet fence, shelves, and open-ended earth boxes to contain the soils for growing vegies, as well as a big compost bin wtih a lid. (found a darn MOUSE in it once), and so on. Still have plenty of wood for anything I can think up that I might have some use for. It was fun.
Tests the pallets, see which boards are easy to shake, and uses the saws to cut the nails, make it as easy on your shoulder as possible, you don't want to ruin your shoulder. Okay, good luck and have fun. Cheers.
myhomelifemag (author) says: Jul 24, 2012. 1:06 PM
Wow! I am so sorry to hear about your shoulder. The expense of ambition, I guess. Glad to hear you are recovering nicely and hope you get to jump back into pallet crafts without too much residual pain.
Thanks so much for stopping by to leave your thoughts. We definitely encourage DIYers to be exceptionally careful as they don't always know the negative effects a beautiful project that shines with self-satisfaction can cost their physical health if not handled properly.
Thanks again for stopping by and we wish you continued healing!!
bstorer says: Jun 24, 2012. 6:48 AM
Cool way to recycle old pallets! I love the ideas made from pallets. Good work and thanks for sharing.
myhomelifemag (author) says: Jul 24, 2012. 1:02 PM
Thanks so much for stopping by and leaving us a comment! We certainly appreciate it :)
If you decide to tackle this we wish you luck and hope you find it functional!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
