Introduction: Stand for Soldering Iron
Stand for soldering iron, will significantly ease your work while soldering and not only that ... He will work to protect the table surface from damage http://www.youtube.com/watch?v=FdY7QlHVUFY&feature=player_embedded
Step 1: 1st Materials, Tools and Accessories
-Materials Tools and Supplies:
-White sheet, the minimum dimensions of 130x150 mm, Needle marking on metal,
0.5 mm thick. Steel ruler
Scissors for metal,
Fine metal file,
Clamp (vise).
Step 2: 2nd Technical Drawing
Dimensions are given in the technical drawings ... Of course they can be adapted to needs, while respecting the given relationship!
Step 3: 3rd Transfer Measures With Technical Drawings on Sheet
Transfer measures with technical drawings on the sheet with the help of steel rulers and pins for marking on metal.
Step 4: 4th Cut the Rack
Cut the rack at the marked lines with scissors for sheet metal.
Step 5: 5th Quality Demersal Sharp Edges Stand
Then, a fine rasp of metal, break the sharp edge of the stand.
Step 6: 6th Shape Rack by Bending Sheet Metal
When edges are handled or lowered, there is still only make a folding stand, marked by lines in such a way that we have marked the lines on the plate, which remained after Notching, facing the side stand, which is facing down (the side that can not see!).
