Stand to reproduce 35mm film and slides with digital camera
 by impcpro
Featured
This stand is easy to make and use, allows a digital camera with macro capability to take pictures of slides and film.
First I designed an acrylic ring with 4 holes for 1/4" acrylic rod avallable at any plastics supply store.
Using Corel Draw or AutoCAD, the dimensions of the ring have to be customized for your camera, I used a 1.8" inner circle and a 3.8" outer circle, the proper dimension for the 1/4" rods is .255" for a tight fit.
I made it at the Tech Shop
Step 1:
Designed with Corel Draw, cut in the Epilog 45 watt laser.
rocketman221 says: May 16, 2012. 12:10 PM
Nice, this is definitely cheaper that buying a film scanner.
You should post an instructable on how to use it though.
Pat Pending says: May 16, 2012. 5:33 AM
Tidy instructable, well executed. I have found that using a black paper mask on the lightbox with a 24mmx36mm opening for the negative/transparency being copied eliminates the effects of stray light and improves image quality.
impcpro (author) in reply to Pat PendingMay 16, 2012. 8:27 AM
You are perfectly right, I cut a heavy black paper mask of the same ring design but substituted the center ring with a 1.42" X .945" rectangle ( 24 X 36mm ) to use as a mask for film, but I did not include in the picture for clarity, with slides it is no problem.
I have copied old slides that were faded and color was all wrong, Photosop did an amazing job.
radiomens says: May 16, 2012. 1:48 AM
good
gserrano701 says: May 15, 2012. 9:52 PM
Looks great and quite easy to build. Could you post some pictures to see the final result?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
