Introduction: Standing Tree Desk
My PhD research is about using computation in the wild, but usually my projects are not as straightforward as this....
Here's the idea: Strap a laptop stand to a tree. Blammo! That's it!
Why?
Well everyone (especially around instructables) always talks about how bad sitting is for you, so everyone makes standing desks. But, you know what else seriously lowers your quality of life? Being trapped indoors all the time! Now you can go do your work, stand up, and enjoy the amazing world around you!
Personal Motivations
Dissertation Writing: This idea originally came up because I am now starting to write my dissertation. I figured that I would feel like a pretty big phony if, while writing a book about how great it is to be outdoors with nature, I was sitting inside my sterile house for the whole semester. This gives me a way to write down my ideas situated in the gorgeous world which I am describing (psst. the second image is a GIF, look how beautiful fall is in Atlanta!). Hopefully doing this will prevent me from including some erroneous assumptions about the world in my manuscript.
Jungle Re-programming: I also started having this idea during my field research in Panama. Sometimes it became necessary to reprogram some of our equipment, but jungles are that great for sitting down indian style, and laptops need a lap (or something else). The best we found was the hood of a truck, but that isn't always there. Being able to toss up a little station anywhere could be really awesome! I can't wait to test it out next summer!
Rights
As with everything I do it goes right into the public domain. The laptop holder was generously provided by Mathew Owen from Fablab: http://www.thingiverse.com/thing:49812/#files and is under a Creative Commons Attribution license. Everything else, especially the concept of tie-tree-to-laptop, is open-hardware and free for anyone to do anything with. Importantly, I want the hardware to be open so that no trolls can come around and sit on a patent, and try to stop other people from making cool tree desks. Also, this is the earliest design, and it has some flaws, so it'd be great to see what people come up with.
Also, this isn't the craziest new idea, I'm sure there's a bunch already out there, hopefully they can point me to those and I can see the even better ideas that may be lurking!
Why?
Rights
Step 1: Gather Materials
The project is pretty straightforward and cheap if you have access to a laser cutter.
Total = $20
Make sure not to buy warped pieces, or pieces that are slightly different thickness; this will bite you later :)
Total = $20
- 1-inch ratcheting Straps from Lowes ($11 for a bag of 4)
- Plywood (2 - $4 2x4 1/4 inch cut in half)
Step 2: Laser Chop and Put Together
Use my modified version of Owen's vector design. I added little slip on clips for connecting to the 1-inch ratcheting straps that go around the tree. I chose Matthew Owen's laptop design above the others because it had a nice curve to the back which I felt would go nicely onto a tree.
Don't get too antsy about not doing an extra pass or two with your laser cutter. Even on the big laser cutter at Gatech, it took 3 passes to cut through the wood all the way. You don't want to mess with cutting out partial cuts.
Also my wood had slightly thicker thicknesses, which meant that to get the parts together I used my dremel to open up all the gaps a little bit. Annoying.
Step 3: Test It Out in the Wild
Originally I added the little belt-clips onto the laser cut design, figuring that it would hold everything. They look a little scary, but are actually really sturdy! The best solution I found was to first get a base strap through the big main hole. This provides a lot of support while letting you still adjust it. Then, fit the top strap around the tree at the height where you want the laptop, and then slip on the clip. Then ratchet it all tight! The stability of the thing kinda freaked me out. My first demo session was for an hour, and I had a great time!
Step 4: Alternate Uses
We were so eager to test it out that we didn't even wait until we were outside and had a tree. Instead we used me as a tree just to see how sturdy it was. Little did we know that this would lead to some great alternative uses for it too!
You can strap it to your chest, back, or belly, and have it serve as a standing desk for others, portable desk for yourself, or mobile bookholder. You could probably store little bags of popcorn in it and sell them at ballgames.
Step 5: Future Designs
The biggest problem with this design is lack of portability. I originally wanted to laser cut a laptop stand with the idea that it would be a quick assembly/reassembly in the field, and otherwise it would flat-pack. After I press-fit this guy together though, it is not coming apart without breaking. But I have new designs in the works! I was thinking going simpler. Two planks and a hinge. What ideas do all you have?
