Introduction: Star Trek Command Badge
For halloween I want to be the red guy on the away mission, lol. It's sad cause I don't think a lot of people will get that joke.  Anyways as part of the costume I need a starfleet badge.  As I am a student my budget for this is zero.  So i had to improvise.
Step 1: Materials
Tools:
-Scissors
-Printer
Materials:
-Glue Stick
-Aluminum Foil
-Card paper (I used business cards)
-badge template
Step 2: Template
Using the internet find an image of the starfleet or any badge you want to create.  I copied the image and pasted it into microsoft word where I adjusted the image size to my preference.  Print 3 images.  Take the three images and glue stick them onto the card paper.  Cut out the images so that one image is the whole badge, the second is just the middle, and the third is just the star. The image with the whole badge will become your template.
There's a word document with the templates on them, they should work for all windows ms office word 95 and up.  I used the smaller of the two sizes.  You can also change the size to your own preference.
Step 3: Building Thickness
-Take your template and trace it 6 to 8 times depending on how thick you want the badge to be.
-Cut these trackings out and glue them together.
-While the cuttings dried I placed them under some text books to ensure proper contact of the layers.  -Note that I also glue sticked the template on the top layer. We will later use that image to aline the other two parts of the badge.
-Once the layers have tried you'll notice that they may not be perfectly flush with each other.  Take your scissors and using one of the blades scrape the sides of the badge until they become flush.  It doesn't take too much effort or force.
Step 4: Adding the Detail
-Glue on the two other parts if the badge. Use the image to position them properly
Step 5: Foiling
-Cut a piece of aluminum foil. Decide on which side you want to use as one side is shiney and the other matte.
-Glue stick the opposite side of the foil that you want.
-Glently place the face of the badge against the glued side of the foil.
-Flip it over and with a cuetip gently rub the foil onto the badge.
-Cut the access foil around the badge leaving enough to fold over the endges.
-Apply glue to the sides and back of the padge and gently fold the foil over the edges of the badge.
Step 6: Fasten and Done
-Glue a safety pin or magnet to the back of the badge.
I did this in about 30 min.  Have fun and I hope this was helpful.
Halloween Contest
Halloween Contest
