loading
Step 12: Right Front
RIGHT FRONT
Note: you can use 1 1/2" binding instead of 2" on right sides of K
a. Fold K vertically, right sides together, matching seam lines and mark center/fold
b. Turn under bottom seam allowance of K to wrong side and press (clip into seam allowance as needed to make allowance lie flat at point)
c. Push lining H/P aside so it will not be caught in the next steps
d. Place top point of K's seamline 7/16” down from top of turned edge of collar at junction of A/B. Align wrong side fold of K with A/B seam on right front. Pin or stitch baste K in place on top of A/B
e. On top right side of K, align binding seamline with K seamline leaving 1" tail on each end
f. Stitch from center top point of K to end of seam
g. Press binding towards shoulder
h. Align left front with right and mark placements for snaps at shoulder/outer point and next snap in. Do not attach outer snap at this time, instead start on next one, sew through binding and K layers only
i. Continue to add snaps moving towards center of K, measuring 1 1/2" post to post and verifying placement by aligning with right front
j. Add chain segments between snaps
l. Trim seam allowance close to snaps and excess binding seam allowance if required to fully turn under K
m. Turn under K and blind stitch binding in place
n. On right side of K, align binding seamline with K seamline leaving 1" tail on each end. Recommend fitting jacket with right front over left, to ensure proper placement of binding below K
o. Stitch from top, across previous binding, to bottom
p. Fold tails under and press binding out
q. Align left front with right and mark placements for snaps at shoulder/outer point and next snap down. Do not attach outer snap at this time, instead start on next one, sew through binding and K layers only
r. Continue to add snaps moving down to bottom of K, measuring 1 1/2" post to post and verifying placement by aligning with right front
s. Add chain segments between snaps
t. Trim seam allowance close to snaps and excess binding seam allowance if required to fully turn under K
u. Turn binding under K, blind stitch in place, closing fold at top
v. On left side of K, align binding seamline with K seamline leaving 1" tail on each end
x. Stitch from top of to bottom
y. Press binding out
z. Trim seam allowance to 7/16", turn binding under K and blind stitch in place, stopping 2" from hem line
aa. On top left side of K, align binding seamline with K seamline leaving 1" tail on each end.
ab. Stitch from outer edge, across previous binding, to intersecting seamline at center peak of K
ac. Fold tails under, press binding out
ad. Trim seam allowance to 7/16" , fold 1" tail under, then turn binding under K and blind stitch in place, closing fold at top at both ends
ae. Add final snap at shoulder/far right point through all layers except lining
OPTIONAL: Use two lengths of binding, mitering at corner
Follow steps a-d above
e. Lay binding on K right sides together. Leave a 1” tail of binding free, align binding stitching line with K seamline from center front (seam of A/B) to shoulder corner and pin in place
f. Mark corner point on binding, remove pins at corner and on binding only stay-stitch in seam allowance ½” on either side of corner. Clip seam allowance to stay-stitching at corner mark, and repin binding
g. Begin stitching binding vertically at tip of A/B to seamline, turn and continue to stitch binding in place along seamline, pivoting at corner and folding excess fabric out of the way, down to bottom of K. Leave tail for binding to continue to bottom of jacket for later fitting.
h. Trim seam allowances to 7/16”
i. Remove seam allowance from unsewn edge of binding down to end of stitching
j. Press binding out to edge
k. Fold tails to inside and turn binding under
l. Sew binding outer edge in place with blind catch-stitch (or topstitch)
m. Place snap at point and sew through all layers except H/P
n. Add next snap at 1½” from post to post. If using sew-on snaps, ensure your stitching does not run along the outer edge of the binding. Continue to add snaps across top to center front and down edge to waist, measuring after each snap.
o. Center chain segments between snaps and sew through all layers except H/P
p. Topstich across bottom of K.
q. Align seamlines of A/B/K and H and pin/baste in place
r. Lay binding on front right sides together. Leave a 1” tail of binding free, align binding stitching line with K seamline from center front (seam of A/B) to flap corner and pin in place
s. Remove pins at corner on binding only and staystitch in seam allowance ½” on either side of corner mark . Clip seam allowance to staystitching at corner mark
t. Begin stitching binding vertically at tip of A/B to seamline, turn and continue to stitch binding in place along seamline, pivoting at corner and folding excess fabric out of the way, down to 2” from bottom front
u. Trim seam allowances to 7/16”
v. Fold tails under and press binding out to edge
w. Turn binding to wrong side. Hand catch stitch with 7/16” seam on wrong side OR stitch-in-the-ditch from the front, being sure to catch binding underneath
<p>A friend pointed me to this Instructables page for help making my own uniform. I couldn't have done it without your advice. I have not yet attached the belt loops, as you can see. You were right about the sleeves not matching at all with the Roddenberry pattern. I did manage to &quot;ease&quot; them down on the torso to make them work, however. Also, I'd like to correct you on one small issue: the right inside facing/lining is not white--it is actually the &quot;self&quot; maroon fabric. If you look at how Uhura wears her uniform in STIII, you'll see she folds down both lapels, revealing a red interior facing on the right side. </p><p>That said, your instruction was invaluable. I could not have done this without your help. Here are the results!</p>
<p>Looks great! I'm glad it was useful. The interior/flap color is based on department, I made a Command jacket which is white, reference: </p><p>http://www.st-spike.org/pages/uniforms/2278-2350/divisions.htm . If you were replicating a crew member their uniform could change over the course of the movies with thier position in the chain of command.</p>
<p>What material did you use for your jacket</p>
<p>Wool/synthetic blend (elastic) for the shell, polyester/rayon for the li).ning (whatever was on sale). See step 2 for a dissertation on fabric.</p>
<p>I just want to say thank you SO much for this Instructable! I would have been so lost with the original pattern's instructions. Your step by step plus pictures was very helpful. This is the most complicated thing I've ever sewed. </p>
<p>It looks great! So glad I could help :)</p>
<p>A debt of gratitude is in order for the tip, it's truly useful for me since this Halloween i am wanting to be dress like Captain Krik, have done my nearly shopping from Amazon store including classic captain kirk costume . you may purchase this for cosplay or to blessing somebody.</p><p>Buy From <a href="https://www.amazon.com/Star-Trek-Beyond-Captain-Jacket/dp/B01IF5H5PO/" rel="nofollow">https://www.amazon.com/Star-Trek-Beyond-Captain-Ja...</a></p>
Did you buy the patterns or did you make them yourself?
<p>I used the Rodenberry.com pattern for the basic parts, then created my own lining and interfacing patterns as noted.</p>
How much fabric was need to construct the jacket?
<p>About 5 yds just to be safe</p>
<p>I don't have access to my pattern to check the recommendations (moving/storage etc). I tend to over buy &quot;just in case&quot; I make a mistake, and purchased 3yds shell fabric but don't remember on the others It also will depend on the width of your fabric, there seems to be a general rule that the fancier/more expensive a fabric is, the narrower as well. I recommend you check the </p><p><a href="http://starfleet1701st.yuku.com/directory#.TynGl-xJJQg" rel="nofollow">http://starfleet1701st.yuku.com/directory#.TynGl-x...</a> site as they will likely already have it posted or have plenty of experienced folk to reply.</p><p>Good luck.</p>
Superb instructable, you saved my bacon as the lack of an exploded view meant I hadn't a clue about the order of construction. Thanks so much!!!
Didn't the movie costumes use magnets to secure the flap?
According to everything I read, the actual jackets used snaps, but the designer (Robert Fletcher) liked the idea of magnets as futuristic and used the chain to convey that. I actually looked at using magnets instead of snaps, but decided it wasn't worth the trouble or expense. I would have wanted strong magnets that would work through fabric, but wouldn't want then too big, and I couldn't think of a good way to secure them except with glue that might leave a hard residue.
I guess you could sew them into pockets between 2 pieces of ribbon, then sew the ribbon between the lining and red fabric. Those strong magnets are pretty expensive though.
That is some of the best craftsmanship or craftswomanship I have seen in this part of the galaxy. Thanks for the detail on the bespoke uniform.
You have no idea how flattering it is to have this called bespoke, here I just thought it was OCD taking over. ;) Thanks
About This Instructable
35,373views
71favorites
License:
More by gephura:Getting more out of your cheap digitizing embroidery software Star Trek Movie Jacket TWOK (The Wrath of Kahn) Costume
Add instructable to:
