loading
Step 4: Pattern Notes
I worked with two different patterns and two different construction guides but found little consistency. I highly recommend drafting up the pattern in a muslin before starting, as the pattern sizing does not correlate to any known size chart I could find on the internet, and you don't want to make mistakes with your nice wool fabric.
Front A/B and Front Facings H & I: The facing pieces have a notch at center front (where A & B join on the front). This is because the collar is stitched right sides together and turned, but the overlap flap (B) is stitched with the wrong sides together with the seam allowances enclosed in the binding applied later. I had trouble aligning the fabric pieces on both jackets at this point, and ended up taking pattern pieces A, B, J, and K (without seam allowances) and tracing new H, I and P pieces.
Sleeve placement: The sleeves turned out to be the most difficult part of the jacket. The designer's notes show the back sleeve seam joining the torso below the piping seam, while some authentic uniforms have the underarm sleeve seam match the torso side seam (A/D junction). I could not get the sleeves from either of my patterns to align in a way that would match either of those placements and still fit the armscye correctly. So I scoured books looking for a rule for placement, but found that the amount of sleeve cap ease and the placement of that ease varies widely by design. It is common to ease only the top of the sleeve and sew the lower portion at a 1:1 ratio with the longer vertical seam running down the back of the arm. The sleeve cap on my patterns was 16% larger than the armscye, which would require a good deal of easing. On my test jacket I tried easing across the top of sleeve piece E from side seam to side seam, but still was left with gathering wrinkles. The pattern that did have notches placed them quite low, so a full 75% of the cap would be eased if they were used as landmarks. In the end I decided to stitch a bias strip along the entire sleeve seam, then aligned the top and bottom of the sleeve and armscye, and this resulted in the piping aligning with the back arm seam.
Back pattern piece: Depending on the pattern, the center back piece might be cut on the fold or have a center seam. Movie stills seem to show a seam down the center back.
Front overlap corner: one pattern had this curved but again after viewing movie still and reading construction guides I changed this to a point.
<p>A friend pointed me to this Instructables page for help making my own uniform. I couldn't have done it without your advice. I have not yet attached the belt loops, as you can see. You were right about the sleeves not matching at all with the Roddenberry pattern. I did manage to &quot;ease&quot; them down on the torso to make them work, however. Also, I'd like to correct you on one small issue: the right inside facing/lining is not white--it is actually the &quot;self&quot; maroon fabric. If you look at how Uhura wears her uniform in STIII, you'll see she folds down both lapels, revealing a red interior facing on the right side. </p><p>That said, your instruction was invaluable. I could not have done this without your help. Here are the results!</p>
<p>Looks great! I'm glad it was useful. The interior/flap color is based on department, I made a Command jacket which is white, reference: </p><p>http://www.st-spike.org/pages/uniforms/2278-2350/divisions.htm . If you were replicating a crew member their uniform could change over the course of the movies with thier position in the chain of command.</p>
<p>What material did you use for your jacket</p>
<p>Wool/synthetic blend (elastic) for the shell, polyester/rayon for the li).ning (whatever was on sale). See step 2 for a dissertation on fabric.</p>
<p>I just want to say thank you SO much for this Instructable! I would have been so lost with the original pattern's instructions. Your step by step plus pictures was very helpful. This is the most complicated thing I've ever sewed. </p>
<p>It looks great! So glad I could help :)</p>
<p>A debt of gratitude is in order for the tip, it's truly useful for me since this Halloween i am wanting to be dress like Captain Krik, have done my nearly shopping from Amazon store including classic captain kirk costume . you may purchase this for cosplay or to blessing somebody.</p><p>Buy From <a href="https://www.amazon.com/Star-Trek-Beyond-Captain-Jacket/dp/B01IF5H5PO/" rel="nofollow">https://www.amazon.com/Star-Trek-Beyond-Captain-Ja...</a></p>
Did you buy the patterns or did you make them yourself?
<p>I used the Rodenberry.com pattern for the basic parts, then created my own lining and interfacing patterns as noted.</p>
How much fabric was need to construct the jacket?
<p>About 5 yds just to be safe</p>
<p>I don't have access to my pattern to check the recommendations (moving/storage etc). I tend to over buy &quot;just in case&quot; I make a mistake, and purchased 3yds shell fabric but don't remember on the others It also will depend on the width of your fabric, there seems to be a general rule that the fancier/more expensive a fabric is, the narrower as well. I recommend you check the </p><p><a href="http://starfleet1701st.yuku.com/directory#.TynGl-xJJQg" rel="nofollow">http://starfleet1701st.yuku.com/directory#.TynGl-x...</a> site as they will likely already have it posted or have plenty of experienced folk to reply.</p><p>Good luck.</p>
Superb instructable, you saved my bacon as the lack of an exploded view meant I hadn't a clue about the order of construction. Thanks so much!!!
Didn't the movie costumes use magnets to secure the flap?
According to everything I read, the actual jackets used snaps, but the designer (Robert Fletcher) liked the idea of magnets as futuristic and used the chain to convey that. I actually looked at using magnets instead of snaps, but decided it wasn't worth the trouble or expense. I would have wanted strong magnets that would work through fabric, but wouldn't want then too big, and I couldn't think of a good way to secure them except with glue that might leave a hard residue.
I guess you could sew them into pockets between 2 pieces of ribbon, then sew the ribbon between the lining and red fabric. Those strong magnets are pretty expensive though.
That is some of the best craftsmanship or craftswomanship I have seen in this part of the galaxy. Thanks for the detail on the bespoke uniform.
You have no idea how flattering it is to have this called bespoke, here I just thought it was OCD taking over. ;) Thanks
About This Instructable
35,373views
71favorites
License:
More by gephura:Getting more out of your cheap digitizing embroidery software Star Trek Movie Jacket TWOK (The Wrath of Kahn) Costume
Add instructable to:
