Star Trek Target Practice
Published
Introduction: Star Trek Target Practice
About: These instructables are mostly about electronics. I hope you find them helpful!
Original HERE: http://tsjwang.blogspot.com/2013/09/star-trek-target-practice.html
I guess I was watching a bit too much Star Trek with my brother. I decided to make a phaser.
Some of you may know that there are multiple types of phasers. I modeled mine after one of these....
HERE IS A VIDEO, basically this whole instructables.
Step 1: Schematic
Here is the schematic.
And a parts list:
Target
- Phototransistors
- two NPN transistors
- $1 calculator
- Some resistor
- 1.5v battery and casing
Phaser
- ATTiny25, 45, 85
- switch
- 2x pushbutton
- piezo buzzer
- 3x resistors (one for LED, two pulldown)
- NPN transistor
- LASER BEAMZ
- OPTIONAL - AVR ISP header
The schematic should explain. Attached is the code.
Step 2: Just a Tip on Taking Apart the Calculator
Like I said in the video, I'm only using the = button on the calculator.
First take the calculator apart. you should be able to find the place where the rubber thing touches the board. Those are two contacts of a switch. Now trace those contacts until you find a spot where you can solder wires to.
You should have four wires after, Vcc, GND, =1, =2.
To find out out where to connect =1 and =2 on the transistor, just test out both ways! It's one or the other.
Step 3: Some Pics of the Phaser
I didn't talk much about how to actually paint, glue, cut the phaser.
Well, I used an old paper towel roll as the handle, and leftovers from a pin wood derby car as the body.
I cut them to shape, glued them together, and painted them black.
After that I completed the electronics and glued those on too.
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
