Star Wars WED Tredwell Droid
 by ToweringProductions
Step 8: Neck and Head
to make the head simple get a couple pre-cut PVC pipe and another that will fit inside the other and glue them together the hot glue will do the job.
make a couple cut of the pvc pip the same size and a couple others that very in size. the total length of the nect should be 38"
prime them and paint them tan once there assembled. use painters tape to tape the tan parts and spray over with a couple coats of the orange.
the head is similar to the body make to two rectangle boxes 4" in diameter with a small pvc base and two of the parallelogram and attach all this to a plywood base. and glue it to the neck.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
