This Instructable will show you how to build a custom Starburst Mirror. I found this tutorial online and decided it lacked some pictures and a few instructions so I am re-posting it.
I don't have a picture for every step as I was not planning on making an Instructable, but this is a pretty easy craft so you will understand the concept.
Step 1: Go shopping
You might have a few of these things around the house (as I did), but you can pick up everything from a craft store or better yet, Wal-Mart. I will list where I got mine and where I could have gotten it cheaper.
Before I list off materials, I will give you a few options. The site I got this from used silver leaf to cover the dowels and I thought that would take way too long and be a pain, so I bought metallic craft paint and applied it with sponge brushes. This was okay, but it took 4-5 coats. I think metallic spray paint would have been a lot faster, so that is up to you.
You will need:
-Scissors
-Scrap Cardboard (anything around your house will work)
-A pen
-Hot glue gun and glue sticks
-Sponge brushes
-Metallic craft paint (97 cents a bottle at Wal-Mart)
or
-Metallic spray paint
or
-Silver leaf (I didn't do this so you're on your own if you want to use it)
-15 Kabob skewers (I had these at home but Wal-Mart had them for $1.97)
-15 12' wooden dowels (I found a bag of 20 at the craft store for about $3.50)
-2 packages of craft mirrors (Wal-Mart had the various size bag of 25 for $1.97)
-A convex auto mirror ($1.97 in the automotive department of Wal-Mart. My best purchase!) -Mounting hardware
Step 2: Paint
First, you will need to transform your wooden skewers and dowels into faux metal rods. To do this, I used a sponge brush and applied 4-5 coats to each dowel. The skewers needed less paint as they were kind of rough and the paint adhered better. If you're hardcore, you might sand your dowels down a bit - I didn't.
Don't worry about painting the whole dowel or skewer as the one end will be hidden - about an inch. When painting the skewers, don't paint the pointed part. Make sure you do, however, paint the top of the dowels and skewers.
Once all the dowels are painted, you should let them dry completely. The last thing you want is some little finger prints in the wood while you're applying them to the mirror.
Step 3: Pre-construction
Open your convex mirror. Again, I found this at Wal-Mart in the automotive department for under $2. It was the best buy I made for this whole project.
The back of the mirror has a really sticky stick-em. You will need to apply cardboard to the back of the mirror so you have a surface to glue the dowels on. I cut a 2 pieces of cardboard about 1/8 of an inch less than the size of the mirror and stuck one right on the back. The second one will be used to cover the back of the project.
Grab a pen and divide the mirror up into 30 ticks.
Step 4: Construction
Using a hot glue gun, apply the dowels on every other tick you just made on the cardboard piece. You can hold the edges of the mirror to keep your fingers out of the way.
Once all the dowels are glued in place, you and glue the skewers in between the dowels. I cut the pointed edge off. You will notice that the skewers don't need as much glue and they will fit right between the dowels. Don't worry if they're not all the same size - it looks better that way anyways.
Once all the dowels and skewers are glued into place, you can apply the second piece of cardboard. Use a lot of hot glue and then slap that puppy right on there lined up with the first piece.
Step 5: Decorating
To snazz up the already sweet looking starburst, you will apply little craft mirrors. Note none of the skewers have mirrors - I felt it would look way too cluttered. I followed this pattern to keep it balanced;
-Large dowels had one large mirror each.
-Starting with dowel #1, I applied a medium and small mirror.
-On dowel #2, I used a medium mirror only.
-On dowel #3, I used a medium and small mirror again.
-On dowel #4, I used a small mirror only.
-On dowel #5, I used a medium and small mirror again.
-On dowel #6, do the same as dowel #2.
See the pattern? Both, medium, both, small, both, medium, both, small, etc. Once you get to the end, you will be placing 2 mirrors next to a dowel with 2 mirrors. Just space them out so you don't notice.
I went totally random with mirror placement. Feel free to place them however you like. You're doing the craft, remember? Geez!
Step 6: Mounting
Your mirror is done! You should be proud... you just pulled off a $80 look for less than $20. Martha Stewart couldn't have done it any better.
At this point, you can use whatever you like to mount it. I used double sided foam tape (found at the dollar store), or you can use a hook, a nail, anything really. Well, probably not anything, but you know what I mean.
You're done! Enjoy.
Tarun Upadhyaya says: Feb 6, 2013. 9:45 AM
I had always played with mirrors a lot and never thought of making such a beautiful starburst mirror. Your ible is so perfect that I made mine without a hurdle. Thank you so much. Its a bit smaller as I only used skewers and added few ornaments to it. Here is what i made
palindrome388 says: Jul 5, 2010. 8:46 AM
Thanks so much for sharing! I finished mine, and I absolutely love it! Everyone that sees it is so impressed that I made it myself!
gegeprada says: Jan 4, 2010. 4:32 PM
 Thank you so much! This is absolutely gorgeous and mine is now hanging in my apartment!! :)
oneprimalscream says: Jul 3, 2009. 1:13 PM
This is awesome! I'm going to attempt to make some mini versions of these to decorate my office space with. Thanks for a great tutorial that achieves the look of an expensive item without draining your wallet.
jessandsteve says: Apr 28, 2009. 9:20 PM
We had tons of fun doing this! It was our first instructable to make!
bebopsamurai says: Apr 27, 2009. 3:21 PM
an idea i had, take it or leave it. the craft store i went to had a bag of uniquely shaped mirror pieces, including squares, diamonds, and teardrops. they were small enough that i could put them onto the piece amongst the skewers, and they didnt give it a cluttered look.
HippieKender says: Apr 26, 2009. 1:06 PM
Thanks so much for sharing this! I just finished mine and I love it! I forgot to pick up something to hang it on the wall with, but will be running to the store soon. I can't wait to see it up on the wall. I've already had requests to make more.
artistikuul says: Apr 2, 2009. 9:05 AM
I have done leafing projects before and its really not too difficult or time consuming. You can substitute aluminum leaf for silver, it is shinier and less expensive. The leaf comes in a pack of 25 sheets called a book with each square separated by a piece of tissue paper. To apply you would paint your dowels w/ a special glue called (size) that is sticky after it sets up (after approx 15-30 mins). The hardest part is handling the leaf, it sticks to your fingers easily and is very lightweight so you want to be sure there is no draft in the room while you are doing it. I sometimes wear clean cotton gloves to avoid it sticking to my fingers. You could cut into strips before adhering to the dowels just be sure to use really sharp scissors or craft knife. Once your dowels are covered use a soft dry paint brush to brush away any excess where it overlaps and to smooth it out. Great project btw, I have always wanted to make a mirror like this.
southphillyitaliana in reply to artistikuulApr 19, 2009. 8:28 PM
I am doing the project a bit easier. I plan to get a block of styrofoam and stick the dowels and skewers into it and use regular metallic paint to paint them, that way there's no fuss about making a mess with the paint. The part sticking into the styrofoam wouldn't need to be painted since I would be gluing them directly onto the back of a larger round mirror I got at IKEA years ago. I found small round mosaic mirror tiles on ebay for pretty cheap. I am trying to make a very large version of this mirror, with the main mirror being 20" in diameter. Good thing I had the wherewithal to even think that this could be a DIY project and searched for it - I almost purchased a $200 starburst mirror online that was much smaller than I wanted!
genesplicer says: Apr 11, 2009. 9:59 PM
Wow! This is a cool project! I had a bunch of brass rod stock lying around, so I did it in brass and used two-part epoxy to hold the rods to the main mirror. Thanks for the idea/instructions!
PindaHoofd says: Apr 4, 2009. 1:29 AM
Do u have a Lg Chocolate?
usedtobelieve (author) in reply to PindaHoofdApr 8, 2009. 10:28 AM
LG Keybo
PindaHoofd in reply to usedtobelieveApr 9, 2009. 7:02 AM
Ok
Mattrox says: Apr 7, 2009. 11:53 PM
very cool 5 stars
Angeldeplata says: Apr 5, 2009. 3:53 PM
Beautifull work :)
MaxineLaRue says: Apr 2, 2009. 2:08 PM
I love your instructable! What a cool decoration. Thanks!
cybermaven says: Apr 2, 2009. 10:11 AM
That is so cool. I'll be making one this weekend! Thanks!!!
RichardBronosky says: Apr 2, 2009. 5:44 AM
For years my wife has wanted the mirror is the JPEG attached this comment. Unfortunately it was (a) 3 inches too wide (b) $600+ (c) gold YUCK! So I set out to make it. I traced out a pattern of it in Adobe Illustrator (Mirror2.pdf attached) to get the proper scale. Then I tried to be more symetrical because that is my perfectionist way (Mirror.pdf attached) and we both hated it. I intended to buy a convex hall safety mirror, aluminum or stainless TIG welding rods, pre-cut 1 inch and 2 inch mirrors, JB Weld (because it is AWESOME!) Unfortunately I never could find a source for 2 inch mirrors. I drew these plans in 2006-2007 and never got to act on them. I would LOVE to find a reliable source for the 2 inch mirrors.
Mirror2.pdf(1871x1871) 87 KB
Mirror.pdf(1786x1786) 248 KB
camscam in reply to RichardBronoskyApr 2, 2009. 9:16 AM
"I would LOVE to find a reliable source for the 2 inch mirrors" At the automotive store they have ones you can stick on your side rear view mirror to give you a bigger view. Also at the bike shop you may find round bicycle rear view mirrors. Woman's compacts also have small mirrors, if you you can extract them from the case without breaking them.
betty2dogs says: Apr 2, 2009. 8:24 AM
I love this look. I can't wait to make one or several for my sun porch.
nak says: Apr 2, 2009. 7:49 AM
If I were alive in the 70s I'd say "That reminds me of the 1970's"
drishya says: Mar 19, 2009. 3:13 AM
nice work...keep it up
RedneckAsian says: Mar 17, 2009. 1:25 PM
would it be possible to ad like a sliding sleeve (no jokes please) to make the smaller mirrors able to slide
j-bar03 says: Mar 16, 2009. 2:27 PM
This is absolutely beautiful. Stunning.
flytape8490 says: Mar 13, 2009. 7:08 PM
This is going to be a great gift for my ladyfriend.
Bindweeds says: Mar 13, 2009. 2:51 AM
Gold on the sticks might be nice too. Maybe add another dimension to it
jacqvb29 says: Mar 12, 2009. 4:06 PM
Looks great! I'm gonna trie to make one.
DIYDragon says: Mar 5, 2009. 3:36 PM
Awesome - I'll be making one of these as soon as I have a place to put it. I just add projects to my 'favorites list' for later. ; )
usedtobelieve (author) in reply to DIYDragonMar 5, 2009. 5:16 PM
I'm glad you like it that much ! Thanks. :-)
hg341 says: Mar 5, 2009. 4:15 PM
wow this is simplei love it and it look GREAT!!
Thanks for posting thisand looks like you paid a lot for it like 50$-165$
lemonie says: Mar 5, 2009. 11:47 AM
Looks great (and expensive). L
Kiteman in reply to lemonieMar 5, 2009. 1:56 PM
I'll say - you can buy "proper" versions of this in Habitat.
lemonie in reply to KitemanMar 5, 2009. 2:05 PM
Don't have a Habitat near me, I thought they'd gone but years ago (shows what I know about home-furnishings...) L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
