Introduction: Starburst Ring Rainbow Loom
This is my second instructable. Please leave comets below to tell me how I did and what I can do better.
Step 1: Materials
You will need:
1) seven rubber bands in one color
2) seven rubber bands in a different color
(All fourteen can be the same color)
3) five or less(depending on the size of your finger)
4) a rainbow loom
5)a hook
6) a pencil (optional)
7) clip
Step 2: Edges
Place the rubber band around a small portion of the edge. Both ends should meet in a point . (Use either color, there should be one of that color left)
Step 3: Middle
Use your other color and place it grime the middle out going clockwise. Start with the second one up on the left.
Step 4: Capping
Place a rubber band on your finger in the shape of an eight and fold over.
Step 5: Capping
Put on either the middle or the outside closer to the end of it depending on the color. If I use blue I will put it on the middle. If I use pink I will put it on he end.
Step 6: Capping
Do it again, this time, use the last color you have left.
Step 7: Pull
Pull the blue (whatever color you are using from under the pink capping band) and bring it to the middle using the hook.
Step 8: Pull
Take the top blue one from the center and bring it to the peg it came from
Step 9: Pull
Do it again for the second blue one on top
Step 10: Pull
Keep repeating till all of the middle ones are capping the outside
Step 11: Edge Pulling
Go back to the end peg and pull the bottom peg and pull to the side it came from
Step 12: Pull Edge
Take he other bottom pink one and pull it the way it came
Step 13: Edge Pull
Go back to the first side you pulled an go to the side. Pull the bottom pink one to the place it came one
Step 14: Edge Pull
Pull the bottom pink one on the next peg and pull to the beginning. Make sure it looks mostly (as in your color doesn't have to be he same)like the picture.
Step 15:
Do same to the other side
Step 16:
Using the pencil or the hook add one of the five to the end and add the clip.. Look at picture
Step 17:
Grab the other end and take off
Step 18:
Make a chain off the hole where your finger was. Use the remaining rubber bands. If to small when you clip the ends together add more. If to big take some off.
