3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Starch Plastic 2.0- Pressure Cooker Hacking
So you have done or were interested in my first instructable on potato plastic and now your looking for something that will yield better results and a little more danger, well here it is. First and foremost I strongly recommend that you approach this project only if you are willing to accept some safety rules, and I will go over those in another step. The basic premise behind making a starch based plastic is to get a starch crammed full of polymers and nothing else, as impurities would detract from the strength properties we want. To do this we are going to have to enter into the realm of modified food starches. For this instructable we will be using a starch that has been modified to have an amylose content of 70% as opposed to the normal 20% found in most starches. The product is called Hylon VII from National Starch Food Innovation. The reason we want a high amylose content is because amylose is "is a planar polymer of glucose linked mainly by hydrogen bonds. It can be made of several thousand glucose units. It is one of the two components of starch, the other being amylopectin". So basically it makes really long polymer chains (good), and if you don't fully understand this go check out my first instructable on Potato Plastic. There is a catch 22 however that puts us in quite a pickle metaphorically speaking, go to step 1 to discover this conundrum.
Heres a video of me doing some strength tests of thick and film-like pieces of my awesome plastic
Step 1The pressure is on
The pressure is on
The starch we will be using: Hylon VII, has a 70% amylose content. The problem is that as the percent of amylose in starch increases, so does the gelatinization temperature. What does that mean? Wikipedia kindly says that "Starch gelatinization is a process that breaks down the intermolecular bonds of starch molecules in the presence of water and temperature and allows the hydrogen bonding sites (the hydroxyl hydrogen and oxygen) to engage more water. Penetration of water increases randomness in the general structure and decreases the number and size of crystalline regions. Crystalline regions do not allow water entry. Heat causes such regions to be diffused, so that the chains begin to separate into an amorphous form." The bad news is that the temperature difference that is needed is rather large. The exact requirements are: "HYLON VII requires higher cooking temperatures than conventional corn starch to adequately gelatinize. Super atmospheric cooking temperatures are required, typically 310-340oF (154-171oC) depending on the solids level of the formulation being used." Hmmmm how can we increase the boiling point of water to 154 Celsius? The answer: increase the atmospheric pressure. With those handy math skills that you learned at one point, you might be able to do the calculations to find out what pressure is needed. But why waste your time when I am going to tell you that it is pretty close to 52 psi and 55-60 psi just to make sure we get it to fully gelatinize. So if you have access to a high pressure autoclave then your in business, if not your going to have to do it the dangerous way. Be cool my babies, we're on to step 3.
20 comments
Oct 22, 2008. 3:10 PMlegionlabs says:
I was researching an unrelated process when I stumbled upon this, I thought you might find it interesting:
Given only potatoes, you might be able to increase the purity of the starch for your process by removing cellulose using this reagent, which can be made from commonly available materials:
http://en.wikipedia.org/wiki/Tetraaminecopper_hydroxide
You can reuse the reagent by precipitating the cellulose out by acidifying the mixture, filtering out the cellulose, and making the reagent basic again.
You can make other plastics out of the extracted cellulose, though I don't know enough to say exactly how.
Dec 5, 2009. 5:42 PMduct tape says:
You can make plastic from the cellulose by nitrating it. Nitrocellulose is soluble in acetone and the first films used in movies were printed on nitrocellulose.
Dec 5, 2009. 5:48 PMduct tape says:
Cellulose nanocrystals can be used to make plastic 3,000 times stronger, apparently. www.newswise.com/articles/cellulose-makes-plastic-3000-times-stronger
Dec 13, 2009. 9:19 PMduct tape says:
For future reference, don't believe everything you see in the movies. But I suppose I shouldn't believe everything on the 'net. Yes, nitrocellulose is very flammable as I have made it before. It's being flammable is why it was phased out ultimately for acetate or safety film.
Dec 25, 2011. 5:10 PMbigjeff5 says:
Another fun fact: Nitrocellulose is also the main component of modern smokeless gunpowder, and can be mixed with nitroglycerin to form a gelatin dynamite.
"Flammable" is potentially a major understatement, depending on what form it is in.
Dec 7, 2009. 6:39 PMlegionlabs says:
Nitrocellulose plastics are used to make ping pong balls, which are in fact highly flammable. The process was invented ~1850, or so claims Wikipedia.
As for the tech press, you're probably right. I bet you can get them to publish anything of the form "Nano(noun) (noun)". Wacky news libs!
In my opinion, small colleges don't get good publications even if they do produce good research; and large colleges get away with producing crap all the time (not that they don't produce good stuff too). MIT ran a study of this effect; while I don't have a link handy this is more or less the same thing (and hilarious): http://pdos.csail.mit.edu/scigen/    (Warning: Not thesis supervisor safe)
But yeah, no research paper = no science and makes baby Newton cry.
Apr 20, 2010. 10:02 PMspectre03cobra says:
Have you tried this with store bough corn starch?
Aug 15, 2009. 8:18 PMDaboJones says:
Good job, interesting product! How well does it age? Does it noticeably fall apart within a month/year? Any progress on removing bubbles? This really could save me some cash for getting things pre-fabbed.
Apr 22, 2009. 4:21 PMvanmankline says:
I'm hoping you may be able to supply more info on the plastic you demonstrate and its uses. How thick is the sheet of plastic pictured over the word "clear"? To what thickness does the product keep that level of clarity? Have you found any transparent dyes for the plastic? Can it easily be cast? If so, do you have any suggestions on mold materials? does it degrade quickly in UV light? Does it weather well? Thank you for any info you may have.
Feb 9, 2009. 12:18 PMrobobadger says:
have you tried making an aluminum oxide ceramic with this? You can use sand blasting Aluminum Oxide with it to increase the strength possibly. Lawrence Berkeley National Laboratory in California scientists found that by freeze drying the aluminum oxide resin mixture then heating it under pressure they got an extremely strong ceramic. Might be worth a try with your potato plastic.
Feb 8, 2009. 7:45 AMdarksparc says:
You should be able to get rid of the bubbles by pulling a vacuum on the container. You will need a vacuum pump as a shop vac will not take the atmosphere down enough. As the pressure in the container reduces the bubbles will expand and pop. All the smaller bubbles will be pulled to the surface.
Nov 25, 2008. 10:13 AMDELETED_PeeWeeBee says:
(removed by author or community request)
Nov 28, 2008. 11:46 AMyokozuna says:
This is very good instructable. If the mold was heated and/or pressurized, would that get rid of the bubbling problem? Have you used this for any practical applications?
Oct 7, 2008. 4:51 PMwingbatwu says:
I'm not an explosives specialist, but in the event of an explosion, steam and shrapnel are not your only concerns... the pressure wave could hurt you pretty badly as well
Sep 20, 2008. 12:06 PMmweston says:
Haha,I love mythbusters! By the way this is pretty cool :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Brandon121233
