The starch we will be using was a free sample from National Starch Food Innovation called
Hylon VI. I usually experimented with a 25:25:1 ratio of water to starch to glycerin by weight, with adjusting the amount of glycerin more yielding a more ductile plastic and less yielding a stiffer harder plastic. Then pour that into a Pyrex beaker and put that into the pressure cooker. Fill the pressure cooker with water till it reaches the bottom of the beaker (about 1/2 inch of water). Then fit your modified top on and start cranking up the heat while observing all the safety rules. When your temperature or pressure gauge reads 320F or 55psi respectively turn off the heat and release the steam out of the valve. When all the steam i gone remove the lid with hot pan holders and pour your hot gel resin into the mold of your choice. Let it cool and harden for several hours them remove and enjoy!
*Note I am still going to be revising this instructable as I do more experiments so keep checking back for more data.
