loading
These directions are for one 9 symbol/glyph 3 chevron Stargate.  Using these basic directions and pattern it is possible to scale up the bed to be larger fairly easily by adding additional gate glyphs to the length.  Please be aware if you are building a larger gate that you will need to increase your materials.
Step 1:
On-hand Supplies Needed:
These are supplies you are likely to have on hand already that you will want to use to build your gate.
• Ruler
• Scissors/Rotary Cutter
• Sewing Machine (or needle and thread with an extra dose of insanity)
• Glue Gun
• Fabric marking pen or pencil
• Electric Bread Knife – Optional, but it does make cutting your foam pieces significantly easier.
Materials Needed:
• 1  piece 1 inch foam measuring 8 inches by 5 ft.
• 1 piece 2 (or 3) inch foam measuring approximately 16 inches round
• Medium grey material – Choose a sturdier fabric such as canvas, duck cloth or denim.  (I chose
a denim)
� Cut 1 piece 10 inches by 5 feet for the gate walls
� Cut 6 pieces 8 inch by 8 inch squares to be cut for Chevrons.
• Orange Material (or light blue for Atlantis Gate)
� Cut 6 piece 6 inches by 6 inches for the Chevrons
� If you are making the Atlantis Gate, you will need to add additional material for each gate
symbol star.
• 20 inch round piece for bottom.  (I chose a heavy canvas in light grey, so if you are working
with canvas for your walls include this piece in that material)
• 1 spool darker grey thread suitable for machine stitching.   +1 spool light blue if you are making
the Atlantis Gate.
• 1 piece Dark Grey/Black Fleece 10 inches by 5 feet
• 1 piece blue (I found a nice tie-dye blue looks great) approximately 20 inches round
For those using metric here's some handy measurement conversions:
½ inch =1.27cm; 1 inch = 2.54cm; 1 foot = 30.48cm
Step 2:
1. Choose your 9 gate symbols you would like to use.  These can be found with a simple internet search and you can customize them to your own desires.  For example, I used star signs of people I knew. One good source is the Stargate Wiki http://stargate.wikia.com/wiki/Glyph
2. Scale your Gate Glyphs so they are no larger than 5 inches high, and print them out for your Symbol/Glyph Patterns.
3. Using the Gate design pattern measurements, mark out the decorative gate borders, and stitch on your medium grey fabric.  Generally you will want to stitch the vertical lines first, and then use the horizontal stitch line to cap off the verticals as that will
produce a more finished look.  Stitch all one border, before measuring and stitching the other border.  For the bottom, I used zigzag stitch for all lines, set to a size similar to one you would use to applique.  For the top, I used a simple straight stitch for my verticals, that I double stitched and then used the zigzag for the horizontal lines.
Step 3:
4. Measure out your gate symbol sections using the design pattern measurements.  You will want to include 1 to 3
stitch lines as a border between your glyphs.  Trace out your symbols onto each section and stitch on.  (For the
Atlantis Gate, use your applique stitch and affix all of your circular “stars”)
Step 4:
5. Sew your gate sidewall into a loop.  That seam should be one of your stitch lines between your first and last gate symbol.  Pay close attention to your decorative borders to ensure they line up correctly.
6. Attach your dark grey fleece interior fabric to the top off your gate.  Try to place your seam fairly close to your top decorative stitch.
7. Using your new formed circle of fabric, trim up your foam so that it fits together snuggly, end to end.  If you have an electric bread cutting knife, that will cut your foam very neat and easy.  If you don't have one... don't sweat the small irregularities in your end... it will all be covered with fabric anyway. :)
8. Heat up your glue gun, and glue the ends of your foam together. (You don't need to take your foam out of your gate-circle, and that will help you out by helping hold those two ends together for you!)
9. Pin down your gate fabric to your foam circle. Pin the outside fabric up from the bottom into the foam.  Pin the interior fabric at a downward angle on the inside in the bottom inch.
10. Glue the outside fabric in small sections to the bottom of the foam circle, pulling out a small section of pins, then gluing down the fabric, and smoothing it out.  Focus should be on gluing the outer edge down and in about a half an inch.  Do not worry about any remaining edge, as that will get covered over with the bottom piece.
11. Glue down the inner fabric piece to the bottom of the inside of the foam circle.  Pull out a small section of pins, smooth your fleece fabric down from the top edge so that it lays flat and then glue down.  Continue around until the whole circle is finished
Step 5:
12. Using your gate circle as a guide, trim your bottom foam to fit snuggly inside your gate-circle.
13. Attach your blue “wormhole” fleece fabric to your bottom base circle of foam by the sides of the foam circle.
14. Fit your wormhole base into your gate ring, and trim any blue fleece edges if you need to.  Set aside, while you work on your chevrons.
Step 6:
15. Cut your Chevron pieces.
16. Sew together each of your two chevron pieces, right side to right side on both angled sides and the short end.  Turn them right side out so that you have 3 larger grey chevron pockets and 3 smaller colored (orange or blue) smaller pockets.
17. Attach the colored chevron pockets to the grey pockets.  (Either by machine or by glue) On a nine symbol gate, that meant my chevrons were between every third symbol.  The open tail end of the chevron should overlap onto the bottom of the bed.  The longest part of the tail, tuck into the “seam” between the base-wormhole and the gate-sidewall.
18. Spot glue the base-wormhole to the gate-sidewall several times for added stability.
Step 7:
19. Using your gate-bed as a pattern, trace out the base on the bottom canvas.
20. Attach the canvas to the bottom of the bed.  I recommend using both glue and some hand stitching to make it look the most finished.  – This bottom part keeps your animal from clawing through to the foam and will extend the life of your bed.
Step 8:
21. Add Cat. - Some cats may prefer to complete this step independently. Wormholes to the Caterverse are extremely stable and once
established will not close unless there is Catastrophic failure of your gate.  In the case of such a major Catastrophe, you may need to take your  Cat to a Veterinary professional for de-wormholing.
Additional build photos are available, as well as a PDF version on my site here: http://misscarlotta.com/tag/stargate/
Cute!!my cat loves it!
These are hilarious and awesome. I love the detail of even having the "wormhole" pattern fabric in the bottom.
Indeed! ^.~
Awesome. <br> <br>Now you need to make a DHD scratching post.
Maybe that's a project for you ^.~<br><br>I was kind of thinking I might try a One Ring next (From LotR)
ooo now that would be cool to see, use a pool noodle cut in half for the shape..I love it. go for it cause I want to see it...go, start making it...
The only problem I have with this build is that cats don't need that kind of thing to teleport whereever they feel like it. ;) <br>
This is the most awesome cat bed /ever/.
Thanks! :D
Your cats are lucky to have someone meet all their geeky needs. Nice job!
Aww... thanks! &gt;^,^&lt;
You must really like Stargate!
Partially that, and partially its a recognizable thing to use for a geek household cat bed. And when I went looking after the second destroyed store bought one, there were a surprising lack of that kind of thing. Lots of suitcases and computer monitors, one person with a millenium falcon pillow... but not much else.
My young cat will be interested, especially if I put it in the clothes closet!
So cool, I bet the kitties love these!
They do seem to get used quite a bit. And are holding up better than the prior ones we bought.<br><br>
it's so they can close their irises ;)
Awesome
Love it!
I never really cared for SG, but I'll be danged if I can't appreciate how slick this is. Aren't you afraid of loosing the cat on some other planet?
Well there are times when say.... a certain animal doesn't stay away from the toilet paper that the idea does have appeal. &not;.&not;<br><br>However, it appears that the Cat-gate connections are very stable and must require some effort to actually travel through.
Hah, nice :)
That looks great! All the detail you put in really makes it awesome!
Thank you! I enjoyed making them, and the cats seem to enjoy sleeping in them!
About This Instructable
13,986views
175favorites
License:
More by miscarlotta:Stargate Cat Bed
Add instructable to:
