Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Also, how do you get the tape stuck to the chair exactly? I can see the first side being easy but, when you stretch it tight to the other side you aren't able to get any overlap with itself when wrapping around the aluminum pipe are you? I would imagine that would start to slide after a while and especially if 300 lb. uncle Rosco sits in it.
So, is this chair still in use and still intact?
The main thing keeping me from running out and doing this instructible right now is getting the two strips aligned *exactly*. (If there is any exposed sticky, such a chair would be suicide for those of us with machoriffically hairy legs.)
Somebody invent this: A duct tape - to - duct ribbon extruder spool!!!
