Start-Stop Dc Motor Control With Arduino
4,329
8
4
Posted
Introduction: Start-Stop Dc Motor Control With Arduino
A simple start-stop circuit that controls a small dc motor via transistor
Parts list
2 pushbuttons
2 resistors 220Ω or 330Ω
2 resistors 10kΩ or 4.7kΩ
1 transistor 2N2222
1 red LED
1 green LED
1 diode 1N4001 (or 1N4002)
1 small dc motor
Step 1: The Code and the Connections
TITLE: A simple start-stop circuit that controls a small dc motor via transistor
Created by: P.Agiakatsikas
DATE: 15/01/17
int buttonPin1 = 2; //Start button
int buttonPin2 = 3; //Stop button
int greenLedPin = 6;//green led start status int
redLedPin = 7; //red led stop status int motorPin = 9; // the motor's pin
int buttonStatus1 = 0;
int buttonStatus2 = 0;
void setup() {
pinMode(motorPin, OUTPUT);
pinMode(greenLedPin, OUTPUT); pinMode(redLedPin, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
void loop() {
buttonStatus1 = digitalRead(buttonPin1);
buttonStatus2 = digitalRead(buttonPin2);
if (buttonStatus1 == HIGH && buttonStatus2 == LOW) { // if the start button is pressed (AND stop button not) digitalWrite(motorPin, HIGH);// turn the motor ON
digitalWrite(greenLedPin, HIGH); //turn the green led indicator ON
digitalWrite(redLedPin, LOW); //turn the red led indicator OFF }
if (buttonStatus1 == LOW && buttonStatus2 == HIGH) { // if stop button is pressed (AND the start off)
digitalWrite(motorPin, LOW); // turn the motor OFF
digitalWrite(greenLedPin, LOW); //turn the green led indicator OFF
digitalWrite(redLedPin, HIGH); //turn the red led indicator ON
Step 2: And a Video
And a video show how it works
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    2 Comments
    The problem is the way the code is copied and pasted. Make sure all the codes are where they are supposed to be,
    So I tried this, but it's not working. I also noticed some flaws in what you said:
    a) You used 5 resistors in your diagram, but only used 4. Which resistor do I need to remove?
    b) I tried compiling the code but it looks like motorPin was never declared, so was the redLedPin. I fixed the redLedPin by declaring it as "int", but what do I declare the motorPin as?
    Thanks
