Start a Guerrilla Drive-in (aka MobMov)
Step 3Now for the hard part...
Just kidding! Setting up the equipment is ridiculously easy! In fact, if you've ever plugged in a new DVD player or TV, this step will probably seem a little obvious. There's really no magic to hooking up your new equipment - video out to video in, audio out to audio in, and power out to power in.
The most finicky part is the FM transmitter. Make sure it is positioned outside your car, and high enough so the top of the antenna is above all the other car antennas. FM antennas transmit sound in an umbrella shape -- any antennas positioned above the transmitter will get much less reception. Also, electronic interference is a common problem - be sure to wrap the ends of your audio cables in Ferrite (magnetic) filters, which you can get from RadioShack or somesuch geek playground, and choose thicker cabling when you can.
If static proves to be abundant, try isolating the cables and equipment from the metal frame of your car (if the interference is coming from the car's power) or grounding the transmitter. Isolating the transmitter itself with a 1ft tall box (I use one of those plastic storage bins you can find at Target) can usually reduce any audio distortion.
The diagram below is taken from my tutorial on mobmov.org and shows how you'd connect it up:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:plusbryan
