3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Start a fire with air
To do this we need to make a firepiston, which is a device for starting cook, camp and signal fires with air.
Firepistons seem so high tech that it's hard to believe they were not developed at MIT or Carnegie Melon under a top secret DARPA contract with unlimited funding. Since the firepiston is also given credit for Rudolf Diesel's invention of his Diesel engine it is quite surprising that the firepiston was not invented by Diesel himself or by one of his contemporaries or the likes of Ben Franklin and other European and American pyro based device inventors of the 16th, 17th and 18th centuries.
What historians note is that the firepiston was most likely invented in conjunction with the invention of the blow gun by prehistoric South East Asians since firepistons are normally found in the possession of those who use blowguns. The need to dislodge the internal partitions at each connecting joint inside a length of bamboo by ramming a rod or piston through the membrane, and in the course of doing so, rapidly compressing the air thereby setting dust particles or the membrane alight, is the reasoning behind co-invention.
I was so amazed at the technology and the science behind it that after building my own firepiston to prove to myself that the science and technology was real I could not resist sharing the science, technology and construction of my first firepiston with you by creating this instructable.
Here then is a description of how to make your own working firepiston to see first hand for yourself that the science and technology do in fact work. I left lots of room for improvement in materials, workmanship and degree of completeness for possible use in the field, if going beyond a demonstration is what you want to do.
Step 1So how does a firepiston work, anyway?
A firepiston can set an ember to burn as a result of energy being concentrated into a smaller and smaller space by compression of air resulting in a corresponding increase in the air's temperature.
The principle of increasing temperature by method of compressing air is explained by the Adiabatic process in which the internal energy of a gas must increase when a mass of air is rapidly compressed (or the volume of space containing a mass of air is rapidly decreased). The resulting increase in internal energy results in a rise in the temperature of air sufficient to light an ember, just like the pressure produced by an ice skater's blade is sufficient to increase the internal energy of the ice, which turns ice under the blade into water.
You can envision the effect in a 2D graph (below) with pressure as the ordinate (vertical) and volume as the abscissa (horizontal) and the adiabat or curve of constant entropy as the inverse relation curve. (Black lines are the curves of constant entropy.)
Rapid compression by a factor of 25 to 1 produces sufficient internal energy to send the air temperature to 800 degrees Fahrenheit. This temperature is sufficient to ignite a piece of char cloth for use in kindling a fire.
After several tries and some fine tuning (better sealing with more lubricant) I was able to produce embers with char twine using the apparatus I constructed.
78 comments
1-40 of 78next »
Mar 6, 2009. 4:02 AMFred82664 says:
Cool I will have to try this out,Is this the same principle that some Diesel Fuel engines start up ( the ones that do not have glow plugs ) ?
Mar 9, 2009. 8:37 PMSpeedmite says:
Glow plugs heat up the engine when You start up a diesel. Thats all they do. Once the engine is hot, the pistons compresses the fuel and that plus the little bit of heat makes it work. I also do not know of any diesels without glow plugs, but it could be possible in hot areas. I'm a teenager thats a nerd and does nothing with trucks and I can tell you that. Sorry I did that. It just bothered me. and yes, its kind like that, but this isnt as powerful as a diesel and a lighter is easy to me compared to this. Just saying.
Mar 10, 2009. 8:52 AMFred82664 says:
cool I like to see the younger generation thinking about other things then sex drugs and rock and role. there all good ,but I am in my 40s I know about the glow plug thing probably be for you was a twinkle in your dad's eyes. ( not meant to make ya feel bad ) older farm tractor did not use glow plugs some of the old Mac trucks and military vehicles did not use glow pugs. I think the use of glow plugs came in around the 60s ,I could be wrong on that thought as well as my thought that friction created the heat to light up the diesel fuel
by all means continue to feed your mind better things then drugs and Challenge current technology make it bettermake new ! (lol my life in some old folks home may be much better by you doing it lol)
Apr 13, 2009. 7:14 AMdifflock says:
You are correct. Not all diesels do have glow plugs... Early diesels were just cranked over repeatedly, which created enough heat due to the compression to start the engine. However, cold weather made it hard to start the engine especially when high compression/high speed diesel engines appeared. Glow plugs were the most successful method of starting diesel engines in cold weather. Some of the methods used before are solid fuel blocks that were fitted into the cylinder head (rudementary glowplug), intake heaters (increase incoming air temp), and introducing ether into the intake. Some example of pre glow plug diesel engines are: - Field Marshall tractors (large single cylinder 2 stroke diesel) which used a solid fuel block, and then later a stogun cartridge style started which ignited fuel in the cylinder. -Stationary diesel engines, like Petter's and Lister's, which are low speed engines that didnt need glow plugs or heater - I believe that the Detroit Diesels featured the ether intake system. Hope that helps. By the way, I'm 19, but have been interested in old engines since I was born :P Old tractors that used TVO still produce the nicest smell :)
Apr 13, 2009. 7:41 PMFred82664 says:
Yes this dose to you young lad you have my honers. you have done well in your studying and investing your knowledge to better living and only 19 at this point of time. I can see much more grate things coming from your efforts in the years ahead of you ! keep it growing
Apr 14, 2009. 1:24 PMSpeedmite says:
Thank you.
Jun 4, 2011. 3:32 PMaverage joe 1999 says:
He obviusly wasnt talking to you.
Apr 13, 2009. 7:22 AMdifflock says:
A youtube video of a Petter PAZ1
http://www.youtube.com/watch?v=Xp3gIpKnswQ
You just crank the engine over and then flick the decompression lever...causing the engine to rapidly compress air causing heat...
Oct 11, 2010. 11:07 AMdkop1 says:
I love my fire piston. I got mine from Wilderness Solutions, (the "Scout" model)
and it's never failed me. It did, however, take me a long time to learn how to turn that ember into a roaring blaze. I've never had problems lighting a fire, but I was accustomed to using flint and steel, or ferrocerium rods.
Any suggestions on natural tinder for fire pistons though? all I've ever used is char-cloth.
Feb 1, 2008. 9:09 PMThe Lightning Stalker says:
This is something I'll have to do in the future. It combines technical things with fire which is an irresistible combination. It'd make a great grill ignitor (I like to grill with real wood)
Oct 21, 2009. 8:33 AMspylock says:
I dont know if you have heard of this,not very technical,but take paper egg cartons fill with sawdust or dryer lint then pour melted wax into each section,when cooled seperate them,they will each burn about ten minutes,a little longer if useing sawdust.
Oct 21, 2009. 2:03 PMThe Lightning Stalker says:
Yeah, actually knapweed and grass clippings work well for that also.  There's actually an instructable on it.
Sep 12, 2010. 2:44 PMtictaclad says:
I take a paper towel, fold it 4 times so its like 1 inch wide ( you have to tear the paper towel) and then soak most of it in wax. leave a little bit without wax so you can light it. they burn for like a candle.
Oct 31, 2009. 8:54 AMfranklinonline says:
 Have you tried nitrate soaked paper? if it doesnt blow it up, you might get a open flame? Nice lighter with nature fuel possible if you fuel ran out.
Oct 21, 2009. 8:17 AMspylock says:
This is where Ive been making my mistakes,I didnt fill the cap,none of the other people told me of this step,thanks.
Aug 16, 2009. 5:59 PMjphphotography says:
I've been looking through all the info on the net on fire pistons and how to make them. I have to say for how simple they look they are fiendishly difficult to make. I finally ordered one so I had a starting point LOL. I'm getting closer now, the current prototype works but not consistently enough for me. Hopefully after a few tweaks it'll be solid and I'll post my own instructable. Another thing I noticed is that some of the materials listed in various fire piston how to's aren't easy to find. For example the longest brass nipple I can find is 4", other people used copper pipe but I can't find anything smaller than 1/2" so its been a challenge just to get the materials let alone getting it to work. Its all fun stuff though!
Jul 15, 2009. 10:52 PMforlack says:
Digging into that website Melon gave down there in the comments, NASA gives you two formulas based on the laws of entropy that you can use to calculate the temperature due to volume changes.
The first is to calculate the pressure change due to the compression ratio (or volume change)
p2 / p1 = (v1 / v2) (gamma)
Knowing that you can then use the second formula which relates pressure change to temperature change.
T2 / T1 = (p2 / p1) ( (gamma - 1) /gamma)
"Gamma" is just a number that depends on the gas. For air, at standard conditions, it is 1.4. (this is a simplification)
For the full workout go to http://wright.nasa.gov/airplane/compexp.html.
Now obviously this has some simplifications, but it should get you a good approximation. Plus their breakdown is for pistons in general which is good.
BTW Temperature is in Kelvin. Using the above equations and with the following:
Compression ratio of 25:1; initial temperature of 25c. The final temperature will be equal to 807c...pretty hot.
Jul 5, 2009. 8:59 PMjphphotography says:
How did the potassium nitrate saturated coffee filters work? Back in high school we used to make smokebombs with that stuff and we'd soak newspaper in a saturated solution of potassium nitrate to act as a slow burning fuse.
Mar 9, 2009. 10:41 AMsharlston says:
any more ideas please email them to mattyts@live.co.uk this is so cool
Feb 1, 2008. 3:20 PMK.hall86 says:
have you experimented with a stainless rod?? the stainless would have more resilience, although you would need more advanced cutting tools. although you might also need to experiment with the width of the o-ring grove...i can see the grove depth and width playing a key role in this. i would assume that the optimum grove width and depth would be the diameter of the ring. that way the ring would have no "slop" in the thrust direction, and it would also guard the ring from trying to roll out of the grove....i am of course assuming a lot here...lol you might try making a piston in very large scale at first....large diameters have tons of structural integrity..it might help work out the kinks in the small scale experiments...
Nov 14, 2008. 1:53 PMn0ukf says:
Have you ever tried to work with stainless? it's tougher to cut than regular mild steel (which is tougher cutting than aluminum)
Sep 28, 2008. 7:55 PMchi chi chippy says:
i have tried to make own out of pvc i saw on a website but i cant get it to start the tinder any one got any suggestions
Aug 25, 2008. 9:32 AMSPININSPUR says:
has anyone come up with one small enough to be put on a key chain. How small can one be made so that the compression aspect is not compromised.i would like to make one as small as possible to carry.
Sep 24, 2008. 5:55 PMchi chi chippy says:
you can make one as small as you want but the smaller, the less tinder (char cloth/twine)you can use. i mean ive seen one as thin as a pencil.
Feb 2, 2008. 12:33 PMKinnishian says:
Very nice guide. But I think explanations are overcomplicated.
Just for one simplification that anyone with some algebra could understand involving why it gets so hot.
Use the formula PV=nRT
Where P = atmospheric pressure. V = volume of gas (air). n = atoms of gas in mols. R = gas costant .0821 and T = Temperature in kelvin.
Keeping in mind P, n, and R remain the same anyone can determine T with simple algebra.
You can use suggestion or not it's still a good guide.
May 2, 2008. 6:26 AMwizodd says:
Easier than that. You need a compression ratio of about 25:1 Calculate the volume of the cylinder. V Calculate the volume that remains with the piston fully in. Vc V:Vc should be 25:1 or more. Note that the wider the cylinder and the smaller the tinder hole, the shorter the stroke length. Nearly any materials can and have been used to make these. The ones for sale on the net are art pieces-like custom knives. When the British first found these, they couldn't believe that they hadn't been invented somewhere 'civilized' as they found them pretty much everywhere the blowgun has been invented. They were just becoming very popular in Europe when the match "lucifer" was invented. Despite the then major disadvantages of the match (early ones tended to light TOO easily, like in your pocket!) Once you've got one they have a number of advantages over the standard lighters ('flint' & steel) in that they are wind and waterproof--if you're not actually under water, it will ignite, and more reliably than most lighters. No fuel to buy as nearly anything that is fluffy and burns will ignite.
Feb 3, 2008. 2:05 PMKinnishian says:
Hmm....Alright :-) My mistake then. We covered the basics of gases earlier, and now we're into enthalpy and entropy. But, I don't think we've put them together yet. My favorite class it tis... Is the difference in the mathematics considerable? Oh, and I suppose we just started trying to determine the K constant for entropy. But I don't understand that yet. Maybe I should go do my homework now :p.
Feb 5, 2008. 2:49 PMKinnishian says:
I was just trying to ask how accurate 'my method' would be?
And you know. So, right, thanks.
Sep 10, 2008. 12:37 AMshadeofsound says:
so incredibly true there
Feb 2, 2008. 7:46 AMSenseless says:
Dang nice Instructable. It reminds me of an old pump design that let's you lift a small volume of water ten feet using a larger volume of flowing water like from a stream but without the need for it to drop like a typical dam system uses to generate force. I can't remember the name of the thing it's been around since the 1800's or so. This will bug me all weekend now trying to remember what it was called LOL.
Feb 22, 2008. 5:44 PMSaint_Awesome says:
We call this a 'waterfall bong', check out youtube for more.
Feb 2, 2008. 3:41 PMwgrover says:
Hi Senseless, it's a hydraulic ram if I'm not mistaken:
Hydraulic ram
Feb 2, 2008. 4:36 PMSenseless says:
Thanks! That's it exactly! I'll be able to sleep tonight LOL. It's like getting a song stuck in your head...
Feb 10, 2008. 3:32 AMharry hardcore hoedown says:
Wow,
Feb 6, 2008. 7:20 PMincorrigible packrat says:
Neato. I wonder if one could be made from a hatchback lift assist cylinder, or maybe one of those little pneumatic cylinders from the surplus store.
1-40 of 78next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
