3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Start a fire with air
Step 6Test the fit of the piston and O-Ring
While it should not be difficult to insert the piston and O-Ring into the nipple there should be obvious resistance from air pressure and the piston should spring back when released. If not try a little more lubricant.
If the piston can not be inserted then remove all lubricant from the shaft and O-Ring, slide the O_Ring up onto the shaft past the seat, put the piston back in the drill and spin the O-Ring on some sandpaper to reduce the outside diameter of the O-Ring a very small amount each time.
Re-lubricate and re-seat the O-Ring and try again. Repeat this process if necessary.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
