Step 8Insert char cloth and test
( Here is an instructable for making char cloth in the field for use with a firepiston...)
A piece of char cloth is inserted in the recess of the piston head and the piston is inserted into the cylinder. A rapid motion is used to drive the piston forward with great force and then withdraw immediately (but with some slight delay).
When withdrawn a small ember should be found which must be nurtured if used to set a piece of tinder alight in order to build a fire.
Do a Google search on the keyword "firepiston" and you can find hundreds of sites on the internet that discuss how to use a firepiston and find videos that show the glowing ember and how it is used to light tender and start a fire. If you have an Adobe Flash Player or add-in you may also be able to view this.
Mine works but until I put on handles I'm not going to develop an operating technique. I have learned that a slight delay after plunging rather than a sort of very rapid bounce worked much better. Experiment.
5
comments
Add Comment
jphphotography
says:
Add Comment
