Introduction: Starting a Bracelet With a Clasp
Picture of Starting a Bracelet With a Clasp
Are you a beginner with beading? Do you just want a refresher on how to? Or do you just want to know how? Well this is the right 'Ible for you:)
Step 1: What You Need
Picture of What You Need
Crimper bead
Wire cutters
Fishing wire (I use this for the thread because it is very durable and cheap)
Beads
Round nose pliers
Clasp
Step 2: String the Crimper Bead and Clasp of Your Choice
Picture of String the Crimper Bead and Clasp of Your Choice
The title explains it pretty much... Just cut the fishing wire with the wire cutters and string the crumpet bead first then the clasp
Step 3: Bring the Wire Back Through
Picture of Bring the Wire Back Through
What you do now is take the tale end and bring it through the crimp bead, after this there will be a big loop with the wire. Bring the bead up so it is tight against the clasp
Step 4: Crimp!
Picture of Crimp!
Use your round nosed pliers to grip the crimper then press as hard as you can check to see if the crimp bead is secure by tugging on it. If it is secure cut off the tale end (the shorter end) and then start beading!
Step 5: Finishing
Picture of Finishing
Do the same as starting;)
About This Instructable
374views
11favorites
License:
Bio: I make and post random and easy things give my instructables a chance and you will love them don't forget to subscribe and make ... More »
More by GeekCrafterGirlz432:Hershey Kiss Wrapper CardsAn Experiment: Dying Yarn With a PomegranateDIY Row Counter
Add instructable to:
