Steady Cam
1,548
16
5
Published
Introduction: Steady Cam
About: I try to build everything.
Hi all, I'm a video enthusiast and for this reason I decided to build a steady cam to get action videos with the smartphone.
The steady cam is essentially composed of a support and a mechanical oscilloscope, and this allows to stabilize the abrupt movements the operator performs while taking a movie.
Step 1: Necessary Equipment
  • A little 3D Printer (working area 150 x 150 mm)
  • Lathe machine
  • Drill machine
  • Hand shaw
  • Bending
  • Tips to drill and metric Threaded Male
  • Keys for screwing screws
Step 2: Part to Build
Some parts are printed on Pla or Abs and a couple of mechanical parts.
Files to print:
https://www.instructables.com/files/deriv/FWQ/NOXT...
anello piccolo
anello grande
supporto telefono
staffaggio telefono
manico
distanziale
Mechanichal parts:
These are the constructive drawings for building mechanical parts:
https://www.instructables.com/files/deriv/FEL/UJM5...
https://www.instructables.com/files/deriv/FK9/6V4W...
Some images of the construction phases:
https://www.instructables.com/files/deriv/FFP/5BQS...
https://www.instructables.com/files/deriv/F1V/2M25...
https://www.instructables.com/files/deriv/FSG/DBX0...
https://www.instructables.com/files/deriv/FV7/0443...
https://www.instructables.com/files/deriv/FN9/2A6P...
https://www.instructables.com/files/deriv/FJB/89D7...
https://www.instructables.com/files/deriv/FEM/E0QR...
https://www.instructables.com/files/deriv/FAP/6EFZ...
To complete the assembly, these components are also required:
N°8 M4 self-locking nuts
N°2 M4 nuts
N°1 Screw TCEI M4x12
N°2 Screw TCEI M4x16
N°2 Screw TCEI M4x60
N°2 Compression spring
diameter wire d.0,5mm
external diameter 7mm
lenght 85mm
N°1 knob M6x10 or a srew.
Step 3: Assembly Video
This is a useful video for assembling all the parts that make up the steady cam.
Step 4: Comparison Video With or Without Steady Cam
Here you can see the difference of a video shot with or without steady cam.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    5 Comments
    thank you for your compliments
    Excellent. The best one yet. Well done. I am certainly making one for me. Thanks a ton
    https://www.instructables.com/member/tomas77/comments/
    Nice. This is probably the most detailed DIY steady cam that I have seen. Most people just use a stick with a weight on it.
    The steady cam I built with my dad and thank you a lot for your comment.
