3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steady cam "KPgyro"
Steady cam \"KPgyro\"
Well, this is my approach to a "BIG" problem - smooth camera movement.
Instead practice, human always want to solve problem with gadgets.
I use an already old  principle of stabilizing object ... known on the ships, from centuries.
And here it is..... gyroscope.
Step 1Idea, material, tools, cut and try...
I choose plexiglas for this. Easy to work with.  I own a camera and according this dimensions i choose the diameter of rings.
First i drill on opposite sides a hole for a small axe from both sides (1,5 mm) deep enough to match two rings. Then I cut on turning machine first ring out.
You can cut this with simple thin hand model saw...but on cost longer time and need to be after carefully finished.
5 comments
Feb 19, 2012. 11:29 PMehagerty says:
Gyro-gadget: also known as a gimbal
Jan 9, 2012. 6:33 AMzerobitjack says:
What you have built is not a gyroscope, but a gimbal with a counterweight. You did a really nice job. Making the gimbal is usually the big challenge for steady cam type projects.
Jan 9, 2012. 2:30 PMbricabracwizard says:
Beautiful work! This something I need!
Jan 9, 2012. 10:25 AMfungus amungus says:
Can we see some video footage of the results?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:KresimirPregernik
