loading
This outlines everything I did to create my first Iron Man suit with a mechanized helmet.  I have always loved the look and concept of Tony Stark's Stealth armor.  This was the first serious costume I ever made and it was a lot of learning through the entire process.  Start to finish took me about 8 months during my free time.  I'll caveat that all these techniques or methods are by no means my own and I have learned from many great people out there.  I am simply documenting the methods I used from all the wonderful resources out there on there net.
Here's my facebook page and my cosplay blog with more WIP pictures:
http://otakuandfit.com
https://www.facebook.com/andrewscosplay
Here is also a grainy video of moving around in the armor.
And my friend and I running aroudn in Iron Man suits during Halloween 2012
Photos courtesy of:
1 - David Lee, Popular Mechanics
2 - Caitlin Holland
3 - Aaron Berkovich Photography
4 - Aaron Berkovich Photography
Step 1: Form Paper Base
Materials I used for this stage:
-110lbs cardstock
-Graphtec / Silhouette SD Craft Cutter (formerly CraftROBO)
-Printer that can accommodate 110lbs cardstock
-Low temp hot glue gun + glue sticks
-Pepakura Designer
-Pepakura Viewer for Craftrobo
1) Find 3D model of the file you want to build.  Google does wonders.  The model I used for my Stealth Mk VI was made by robo3687.  These 3D models will serve as a rough geometric base of what you are trying to build
2) Download required software to open and print your paper model.  Software will show you how to glue pieces together to form the base shape of your model.
3) Cut 3D model pieces with Craftrobo
4) Use Pepakura viewer to assist you in glue required tabs together
Step 2: Harden Paper Base
-EpoxAmite 100 Laminating Epoxy by Smooth-On
-Fiberglass cloth
-Chip brushes
-Disposable cups
-Organic vapor respirator
-Disposable gloves
-Disposable spoons for mixing
-Dremel
-60 grit sanding attachment for dremel
1) Next, I hardened the paper base with EpoxAmite 100 (while wearing gloves and an organic vapor respirator) which is an epoxy resin that is mixed in 2 parts and applied with a chip brush.  I prefer using this over polyester resin.
2) I let the resin on paper cure over night to be safe.  Once cured, the paper will be a tad bit more stiff, but will require fiberglass reinforcement in order to increase durability.  Cut strips of fiberglass cloth, and use the epoxy resin to wet out the area on the inside of each piece to where you will lay the cut pieces of cloth.
3) I covered the entire surface area of the inside of each piece.  Overlapping the outside of the piece is okay.
4) Once the fiberglass cloth cures over night, I cleaned the stray edges with a dremel with a 60 grit sanding wheel.
Step 3: Shaping With Bodyfiller
Materials I used:
-Rage Gold body filler
-U-Pol onion board
-Bondo body filler spreaders
-Bondo spot putty
-Soft Sanders sanding blocks
-Need files
-Sand paper (60 grit, 120 grit, 220 grit, 400 grit)
-Flat (matte) black spray paint
-Automotive primer spray cans
-PATIENCE
When the fiberglass stage is complete, you will have a strong piece but still geometric looking. Below is the basic process in a nutshell of how I shaped each piece and gave it more roundness:
1) Apply body filler
2) Apply matte black spray paint dust coat (basically you spray your piece lightly with black paint as a guide coat when you sand... while your sanding, you'll know where your low spots are as they will be dark)
3) 60 grit sanding
4) Repeat 1-3 until shape is appropriate (I took careful attention to add body filler to the low spots first which will be obvious because of the matt black dust coat)
5) Dust coat
6) 180 grit sanding (this will smooth out the scratch marks from the 60 grit)
7) Filler Primer (This will fill minor scratches and reveal further imperfections)
8) Added detail lines with a needle file.  These are lines that are not a part of the original 3D model that need to be etched in
9) Use bondo spot putty to fill small imperfections on shape
10) Dust coat
11) 220 grit sanding
12) Reprime to remove scratches
13) Light Dust coat
14) 400 wet sand
Step 4: Painting and Weathering
Materials I used:
-Automotive spray paint
-Automotive clear coat
-Detail paint brushes
-Black acrylic paint
-Rub N Buff pewter
1) After each piece was primed and wet sanded with 400 grit, the piece is ready to paint
2) I applied 3 cost of spray paint, 10 minutes between coats (photos 1, 4, 5)
3) 30 minutes after the last coat of colored paint, I applied 3 coats of automotive clear to protect the paint and give it some extra shine (photo 2)
4) The next day, I used a small detail brush and acrylic black paint to “dirty” up the armor.  I would apply the acrylic paint, then wipe off the excess with a wet rag. (photo 3)
5) The last part to give a damaged look is applying some Rub N Buff with a small detail brush and carefully rubbing off the excess to give a scratched metal effect (photo 3)
Step 5: Flexible Pieces
Materials I used:
-EVA foam
-Exacto knife
-Exacto board cutter (for angled cuts)
-Modpodge
-Plastidip
-Automotive Adhesion promoter
-Krylon Low Oder Clear Finish (gloss)
-Chip brush
1) I used form for pieces that I felt would need more flexibility.  I used the foam method for the hands, abs, neck, and codpiece.
2) You can google foam templates for various pieces which you will print and cut with Pepakura Viewer.
3) Once I printed and cut the template, I traced onto my foam pieces.
4) Using references pictures of the part I was trying to build, I varied the angle of cuts in order to get the appropriate shape for when the piece is glued together.
5) Once the flexible pieces were build, I sealed the foam with a layer of modpodge, then 3 coats of black plastidip
6) Automotive adhesion promoter was then applied in 3 coats, then the sprayed with color within10 minutes of the promoter drying
7) After the color paint was dry, I used the Krylon gloss to give the pieces some shine
8) I then weathered the pieces as previously described
Step 6: Mounting
Materials I used:
-Backpack strapping
-Backpack clips
-Rare earth magnets
-Dremel
-Dremel grinding stone
-Velcro
-Hot glue gun with hi temp glue stick
-Elastic straps
1) For the flexible parts, I used a combination of Velcro and rare earth magnets
2) I used a dremel with a grinding stone attachments in order to create a space where the rare earth magnet can fit (photo 1)
3) I used hi temp hot glue in order to hold the magnet in place (photo 1)
4) For the elbow joints, I hot glued elastic straps for more mobility (photo 5)
5) To join the shoulders to arms, I used hot glued backpack strapping  to easily hook the pieces together.  I did the same with the chest and back pieces. (photo 3)
6) In order for my helmet to fit, I dremeled the rear piece out and then attached magnets to the inside with Apoxie Sculpt clay. (photo 4)
Step 7: Electronics
Materials I used:
-Helping hands
-Soldering Iron
-Solder
-22 gauge wire
-9v battery holders
-LEDs
-Scrap foam
-Hot glue
-Velcro
-Mylar folder
-Reed switch
1) For the gloves, I had a 9v battery holder which contained a switch.  I wired and soldered this directly to my LEDs and hot glued the LEDs to the glove
2) I cut out pieces of a mylar folder in order to diffuse the LED.
3) For the eyes, I made eye boxes out of scrap foam and attached LEDs to the inside.  More folder used to diffuse the light
4) LED eye boxes are then wired to a reed switch and a 9v battery holder.  The reed switch closes the circuit when a magnetic field is present (facemask open, eyes off – facemask closed, eyes on)
5) For the chest piece, it was more or less the same with LEDs wired and more red folders to diffuse the light.
Step 8: Mechanizing Faceplate
Materials I used
- Small servos from hobby shop
- Push rods
- Pololu Micro Maestro 6 microcontroller + Users guide
- Wire
- 100 ohm resistor
- Soldering Iron
- USB cable
- 2 x 6v rechargeable batteries
- Chicago Screws
- Sintra
- Hi temp hot glue
- Apoxie Sculpt
1) I purchased hinge plans and installation guide from another Iron Man maker to save me the time of designing hinges, although there are a lot of other good sources on the hinge topic out there
2) I made the hinges out of sintra.  I cut them to shape then sanded down the rough edges.
3) I glued Chicago screws into place for the hinges, and then used Apoxie Sculpt to fixate them in place.  I sanded down the excess as well.
4) One I had smooth movement of my faceplate, I began the installation of 2 servos in the helmet.  I experimented with different positions of the servos, but ultimately the initial suggestion of having the servos in the back of the helmet became the best working.  I hot glued them which seemed to hold fine
5) I then measured and cut down pushrods to connect the servos to the hinges.  I manually tested the motion in order to determine that the placement was satisfactory
6) I then followed the manual for the Micro Maestro microcontroller in order to wire a button to one of the chip’s channels.  This will be the button that activates the servos
7) I followed the example script in the manual in order to have a push of the button activate servo movement.  Once understanding single servo movement, I modified the script to move both servos
8) After having both servos in motion, I carefully modified the script in order to obtain the proper servo movement for my helmet.  I noticed there was a point where the servos would rotate the hinges too far, thus warping the helmet.  Once I reached that point, I returned it to a point where it would not warp.
Here's a short video of servo action on my second helmet using the same method:
Step 9: SUIT UP!
Action mode!  Thanks for reading!
Photos courtesy of:
1) Keigo Mak
2) Marvel.com
3) comingsoon.net
4) Me =P
<p>How do you see out of the helmet?</p>
<p>absolutely incredible!! Great job!</p>
<p>Seen this ages ago and once again dude amazing work</p>
<p>5555</p>
<p>awesome!!!!!!!</p>
<p>Congrats </p>
Would you make and seek it to me? This is so awesome!!
Sorry typo sell
Yeah how much would all this cost
<p>what scale did you use? I'm scared that my suit could be too big in the end</p>
<p>do have to use rage gold or can you use another body filler</p>
<p>how much did it cost you</p>
<p>Hi!</p><p>I was able to make the first Cut out model however its too big, can you teach me how to re scale the size? I already have all the PDO files from head to foot of the armour, I just like to make an armour fit me. I am 5 11&quot; height also the foot dimension too. please email me at chua111181@gmail.com.</p>
Here's an older ad
Did you know theres a guy in NJ posting he made your Iron Man &amp; scamming ppl?
Oh wow, no I didn't. Do you have a link you can send me?
<p>wow.. awesome.. i unable to finish this project of mine. <br>Wish i found this earlier.</p>
<p>cool as bro I just want to know how you see</p>
How did you make the hands so detailed
<p>what reed switch did you use?</p>
Did you do anything with the inside of the helmet or did you leave the fiberglass exposed?
Great instructions! <br>Although, how do you open the file is the problem. Would you mind putting a zip with the pep files?
That is the most bitchin thing I have ever seen!!! I want one! Love the helmet's servo too! How much is it?
what was total cost and time of this project <br>
Now... Where's that favorite button
how much would you say it cost to make. I'm thinking of making a iron man suit or a batman suit.
Congratulation! Very nice suit! I was just wondering where did you place the button to open and close the facemask? Can`t find something trough the the various steps even in the videos...How does it work?
Where could I get a copy of the paper base?
Just a small question, did you take Robo's MarkVI suit and just make it black? I've been looking at trying to make the MarkVI suit and this just blew my mind. I only ask because I have the Pepakura files for the MarkVI and I really don't feel like downloading all of those files again. <br>Thanks! <br>-usMudack1998
Words are beyond me man, really really nice job. <br>Looks amazing, as soon as i can i'll try to replicate it, and i'll swarm you with questions hahaha. <br>Once again my congratulations it looks awesome!
Respect! My mind is still boggling at the learning curves alone involved with a project like this... And the results are worth it ;)
Hey I plan on making this and I was just wondering what are the conditions while wearing it like is it hot heavy awkward to wear<br/><br/>
Looks great! Are you able to sit down in it? I can't imagine going to a con, walking all over, standing in lines and not being able to sit for a minute.
What paint did u use to make the suit? <br>
very awesome dude but can u see through the eyes holes in the helmet or is it a light in the way?
I can see =P
The guys in the prop department where I work are going to love this, I know what we're doing for the next 8 months
is the program that you used like solidworks?? <br>love it btw cant wait to make my own!!!!
Is It hard to make one in another size? I mean, i'm quite small, will i be able to make one in my size?
I was wondering, how much cardstock is needed and what size sheet?
Hi! I&acute;m really loving this tutorial. Since i actually speak spanish, would you be so kind explaining to me what steps 10 an 13 are? what do you mean by dust coat? Thank youuu &hearts;
great job - nice detail on the project
CONGRATULATIONS! Great work man!
Thanks!
Congratulations on being a finalist in the Halloween contest!!! Can&rsquo;t wait to see if you win! Good luck!
Oh wow, thanks! I didn't even know until I saw your comment =P
Excellent suit my man, beautiful execution and i love the colour choice. i love using the Pepakura stuff its such a convenient way to make almost anything. hope to see more stuff from you in the future. all the best
good job ! <br>i was wondering: did Disney contact you for the right (just killing...) <br>may be for that reason you did it blue instead red ? <br>again good job, clean, and cool helmet ! <br>(from a french user., well, ...reader)
Thank you! I just always liked the Stealth version <br> <br>http://www.advancediron.org/images/iron-man-stealth-comiquette-sm.jpg
Very Cool. Wish I had the time to make something like this. Great job! Btw how long did it take to make?
About This Instructable
244,161views
1,406favorites
License:
Bio: http://otakuandfit.com - Nerd, exercise/nutrition enthusiast, amateur cosplayer and armor maker =) Gotta use my electrical engineering degree for something!
More by mizunohadouken:Raiden (Cyborg Ninja) w/ Motorized Face Shield from Metal Gear Stealth Iron Man with Electronics and Servos
Add instructable to:
