Stealthy Altoids Tin Grooming Kit
6,753
55
5
Posted
Introduction: Stealthy Altoids Tin Grooming Kit
The Stealthy Altoids Tin Man Grooming Kit , is perfect for keeping in your desk or car for those times when you really need it.
Supplies:
Tools:
Sharpie
Knife or scissors
Hot glue gun
"Ingredients"
Altoids tin, color of choice
Colgate wisp toothbrush
Fingernail clippers
Tweezers
Razor blade
Pocket sized travel mirror
Altoids Smalls
Free sample of cascade tooling foam
or anything you find necessary on the go!
Step 1: Foam Layers
First trace the shape of the altoids tin onto one of the pieces of tooling foam.
Next cut the piece out, cut inside the lines so it will fit inside the tin.
Repeat the process twice more, two layer on the bottom and one on the top.
I did two red and one black.
Step 2: The Mirror
The mirror I found was a little big, so i cut the top piece of foam into two pieces to make room,  I also cut a strip from the bottom of the foam to allow the top to swing over and the tin to close.
Next I used hot glue to set the two pieces in place.  I cut some small pieces of the black foam to act as supports for the mirror so that it would be at close to the same height as the foam.
Adding a drop of hot glue to each of the black foam supports, glue the mirror in place.
Step 3: The Tools
Now, lay out the tools to get an idea of how they will fit.
Next begin tracing and cutting out the shape of the tools
Make sure to leave some room to keep the Altoids Smalls.
Apply a small amount of hot glue to the back of the cut out foam(Black), attach to the lower layer(Red)
Now apply some glue to the bottom of the Altoids tin and set the red and black piece together against the glue.
Step 4: The Kit!
Now it is time to populate the kit.
Fill all of the spaces in with the appropriate tools, and prepare to impress with your newly found discretely well groomed appearance on the go!
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
5 Comments
where did ya get the foam pieces?
Love the idea. Stealthy indeed. A cut-down comb, a spot bandage for a nasty zit that invariably pops up right before a meeting/date, and a bit of dental floss would be the additions I would make.
Nice idea adding just the razor head, makes things much more compact. If I try this, I think I'll slide a small comb under the foam somewhere. Thanks for posting this!
Useful! i usually do have some of these things tossed at the bottom of my bag, might give this a go
