Steam Engine
Introduction: Steam Engine
Im going to teach you how to make a steam engine
Step 1: Stuff
Soda can Duct tape String or twine Something to make a hole with
Step 2: Something to Hang On
You will want to bend the tab up and tie your string around the top hole of the tab and put a piece of tape around the knot
Step 3: Wrap in Tape
I did this just for a stronger structure and for looks
Step 4: Holes
Poke two holes in opposite sides of the can at opposite angles
Step 5: Power
Fill about half way up the cans or just under the hole
Step 6: Use
To use this you need to hang it above a fire with water in it i did not add this part to the intractable i will however try to make a stand for it the future
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    This wont work as is.
    The steam will go out the top of your can.
    Once the top of can is sealed it may twist a little on the twine but the holes are not directing the steam in a certain direction other than "out".
    What are you trying to power with this by the way? And how?
    meant my las comment as a reply sorrry
    i'm not trying to power anything with it it was just an idea i will probably edit it so you put a piece of duct tape over the top but thats is why i said in opposite directions on either side so instead of going "out" it will turn also i forgot to say you need to mount it on a free pivot point but
    sorry for the mistakes i will fix them asap
    i haven't been able to test yet works in concept please tell me how it goes
    If you like this please go look at my other instructible
    Strengthen the can and for looks
