3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steam punk Flashlight
This is a projectt I started a few months ago, it's a work in progress and hope to have it done in about a week.
I have no idea where that reflector came from it's ceramic and hallow.
The case is made of an old oak pallet selected for it's personality, the bottom slides out for access to the
batteries, or what ever, still not sure if it's going to electric or a gas light.
20 comments
Jan 29, 2012. 10:03 AMdiy_bloke says:
It is gorgeous. The refelctor, at least on the pics, looks like the lid of a pan, without disrespect. It is a gorgeous creation
Jan 29, 2012. 10:05 AMdiy_bloke says:
The shiny tubes at the back might be a bit too modern for this creation. Consider wrapping them in something like old rubber hose, or cloth
Jan 15, 2012. 9:15 PMrobotjim says:
Very nice...as are the rest of your steam punk creations!
You've probably finished it by now, but if you are still considering
gas as a light source you could try acetylene. It would likely be historically
accurate and easy to make. Just add calcium carbide to water and
it generates acetylene.
Miners used this type of light back around the nineteenth and early
twentieth centuries. A friend of mine used to have one, quite bright and
lasted a long time as I recall.
OK, the required safety notice...acetylene is of course quite flammable and
as I recall from using in for welding, explosive at higher pressures (not likely
to be reached in an acetylene lamp...).
Keep creating!
Jan 16, 2012. 10:50 AMrobotjim says:
Now how could I have spent so much time with an oxy-acetylene setup around
and never tried that with a balloon!
I'll have to combine that with another interest and see if I can set it off with a laser!
Ok kids, you know the drill "don't try this at home"...I'm a professional with years
of experience... ;-)
BTW, just looked on Ebay, you can still buy carbide lamps...a bit pricey as they
are considered collectibles these days though.
Just noticed where you live, aha, now the nick name makes perfect sense! I
have a brother in law in Fairbanks...
Nov 25, 2011. 11:55 PMbakermiro says:
cool, very cool
Nov 24, 2011. 10:41 AMJunophor says:
Well Sir
A very convincing work indeed. Well done. This gives me a new inspiring idea......
Nov 21, 2011. 11:33 AMWinged Fist says:
Great design! The case is really well made... It reminds me of my father's old shoeshine box from the 1940s;-)
Nov 20, 2011. 10:24 AMelectfire says:
Nicely done! I would opt for gas, as that seems to be your niche but I think that this light in particular, is looking like it would be more apt for electric, seeing as you have so far used some nice insulators (where did you get those!)... then again you could to a hybrid design, where it looks like it uses gas (or some other fuel) and generates electricity.... (hmm steam-turbine generator maybe), it would necessarily actually use a fuel, but it would look like it does.... (hopefully I am making sense here...)
Nov 20, 2011. 7:01 PMelectfire says:
*In my announcer voice* "....and the most inefficient light award goes to.... (drumroll please)...Loooong Winters!"
All jokes aside... if you use the HO gas (what the combined Hydrogen and oxygen gasses are called) , it won't make a "small" flame- it will make a HOT flame- HO torches are the hottest torches... but efficiency is poor as it's hard to get a perfect balance of the hydrogen and oxygen, and also the amount of electrical energy you put in is often more than what you get out.... usually you need high amperage do get a decent amount... (esp. if you are directly using the gas, straight from the HO cell, and not storing it....)
ALSO HO gas and HO cells can be very dangerous as any stray spark could ignite any small leak.... I definitively wouldn't suggest trying to make a portable version... nor would I put it in a wooden box...
Anyways (sorry for the lecture, I didn't mean to lecture.... >
Nov 20, 2011. 7:13 PMelectfire says:
Opps It cut me off!
Anyways, you could take small HO cell and use it to either heat a camping mantle to incandescence (but it might burn it) or you could use it to heat a piece of quicklime to incandescence, which is your best bet.... not only could you use a different (and safer) fuel source to heat it... but "lime"light is very much in the time period in which steampunk emulates (i.e the 1800's)
Here is an article from the "Worlds Most Unreliable Encyclopedia"
http://en.wikipedia.org/wiki/Limelight
And here is an article from one of my favorite source for chemistry info, Theodore Grey ....
http://theodoregray.com/PeriodicTable/PopularScience/2007/09/1/index.html
Nov 20, 2011. 10:52 PMelectfire says:
Wow, love that bulb! Let me guess... it's a plain old ordinary light bulb, that you cleaned out, and then added some glass piping in it... (or I could totally be wrong!)
Nov 21, 2011. 11:38 AMelectfire says:
(O.D. on LED envy) I will love to see this lit up!
You inspired me (after I saw this last night) to take an old flood light bulb that was burned out and clean it out- I think it will be perfect, cause it almost looks like an old cathode-ray tube (CRT)... I am thinking of putting a few RGB LEDs inside so they light up the front (like a screen)... unless I can find a way to project text and info onto the the front of it... hmm... I just had an idea...too bad I don't haven the old projection clock I had anymore... but I might just be able to work something out... Anyways I would love to see this lit up! (Keep up the nice work!)
Nov 19, 2011. 3:01 PMdoomsdayltd says:
sweet
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:longwinters
Happily married, self employed, full wood shop, some metal work as well as electronics, antique collector.
